Split Bus Panel. Should I Rip It Out? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2011, 05:08 PM   #1
Split bus panel. Should I rip it out?
My home was built in 1978. I have a Gould 150A split bus panel. The first 4 breakers are double size and do:
Electric Range, Central AC
70A "main", Electric Dryer
The rest are the mini breakers (2 small's in the size of 1), except for 1 GFI breaker that goes to an electrical outlet in each bathroom (2 of them).
I was always perplexed as to where the heck was the main? I've replaced outlets and switches in rooms from the 1970's brown to a more modern white. Whenever I shut of the power, I always have to double check.
So do you think it's worth ripping out this 1978 split bus panel and put in a regular 200A panel with normal sized breakers? I don't have any non-living space that could be renovated, so 150A service works fine. But whos to say 10 years down the road we don't install a hot tub or something like that?
Anyway just really need to know if it's a hazard or code violation. The home inspector didn't bring it up. The only thing he said about it was that the GFI breaker was old and he'd rather see a regular breaker with a GFCI outlet in the bathroom. Well I put a GFCI outlet in the bathroom because I wanted all white outlets and switches so it looks nice. I also change the 1978 outlets from back stabbed connections to using the screw terminals on the newer stuff.
cypherx is offline   Reply With Quote
Old 09-29-2011, 06:13 PM   #2
Licensed electrician
Rewards Points: 1,754
The double pole breakers at the top together act as the main. You are allowed up to 6 throws of the hand to shut off the power.
Old 09-29-2011, 07:51 PM   #3
Rewards Points: 266
As long as the panel is not deteriorated (rust/corrosion) or broken or missing parts, I'd probably leave it and upgrade when or if you need it.
junkcollector is offline   Reply With Quote
Old 09-29-2011, 09:30 PM   #4
Rewards Points: 6,652
If wanting to expand, keep the split and add a appropiate sized sub for whatever you are doing.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 02:05 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
