Split From 200 Amp - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2012, 06:07 PM   #1
split from 200 amp
split from 200 amp main to 100amp from main box but; due to code; I can't have more than 90 amp to the main in my shed. Does this make sense; and if it does, it doesn't seem I can convert the 100 amp box without too much extra work. Does anyone sell a 90 amp breaker box?
ralph jenkins is offline   Reply With Quote
Old 04-05-2012, 06:09 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You can use a main lug panel and feed it with a 90 A breaker.
Old 04-05-2012, 06:13 PM   #3
If I understand you correctly, I can feed off a 90 amp breaker in the main and feed it to a 100 amp breaker in the shed??
Old 04-05-2012, 06:16 PM   #4
k_buz's Avatar
Out of curiosity, what size and type wire (AL/CU) is run between the main and sub panels?
Old 04-05-2012, 06:21 PM   #5
not exactly sure of the wire size; I don't have the rcpt in front of me; but it is 3 wire aluminum
Old 04-05-2012, 06:22 PM   #6
k_buz's Avatar
You cannot feed a sub panel with 3 wire cable.
The Following User Says Thank You to k_buz For This Useful Post:
Speedy Petey (04-05-2012)
Old 04-05-2012, 06:27 PM   #7
Thanks I think!
I'm going to double check with my little "electrician friend"
I'll get back to you tomorrow..OK?
Old 04-05-2012, 07:14 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Originally Posted by ralph jenkins View Post
Thanks I think!
I hope you little electrician friend is more of an electrician. If he told you to get 3-wire then he is doing you a disservice, and inviting quite a big re-do when it (rightfully) fails inspection.
If it is #2AL then 90A makes sense.
Old 04-05-2012, 07:54 PM   #9
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
That's why I never believe a local electrician for advice or help because they are not always going to give you correct advice. If I can't figure out the NEC handbook I post somewhere like here or do some searching online then ask the local inspector what he expects.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-05-2012, 08:00 PM   #10
k_buz's Avatar
Yeah, but your area/state is strange. You don't have to be a licensed electrician to do electrical work...which I think is really scarey.
Old 04-05-2012, 08:56 PM   #11
rrolleston's Avatar
Very true. At least some people try to do a decent job. But there is no way to compete with the hacks that don't want to fallow code.
Mini split in basement? Mills314 HVAC 1 07-04-2011 09:36 AM
Split floor joist scottyv81 Building & Construction 6 12-23-2010 02:42 PM
Split Air Returns Earnie HVAC 6 02-06-2010 07:29 AM
Repairing Split in Wood Door? diyintexas Carpentry 4 10-11-2009 01:00 AM
Split 3-phase mdwkailua Electrical 21 04-07-2009 01:55 PM
