I want to add an exterior motion sensor light to an exterior motion sensor light circuit at the electrical breaker box.
My proposal is since:
1) I have material to make it to the new light from the breaker box and not further.
2) I can't double tap on the 15A GFCI circuit breaker that serves the circuit.
3) A junction box somewhere else is not really an option.
4) I am running out of breaker spaces in the breaker box.
5) I have more than enough area/volume in the breaker panel.
to run a 14-2 wire from the new light to the 15A breaker. The plan would be to splice the black wires together using an appropriate wire nut to a black pigtail and land the pigtail on the appropriate location on the GFCI. In turn, I would do the same thing with the white wires and land the white pigtail on the appropriate location on the GFCI. All derating of the NM-B cable and breaker is done. Would this meet code?
Yeah, we get it. You are in Canada, even though your profile is empty.
That is why I specifically quoted your sentence. It IS allowed by code in the US. And it is NOT at all unsafe. Your logic could be applied to any number of different scenarios. In fact, I consider it safer since you know for sure that a panel will be bonded.
Sorry, I don't buy your logic at ALL. I actually think you are trying to convince us (and yourself) that it is somehow safer simply to justify the fact that it is a code violation according to the CEC.
The NEC and the CEC are quite similar, but the CEC has some dumb codes. Like only 20A receptacles on 20A circuits.
Don't get all bothered that I say this. The NEC has it's share of dumb codes as well.
There is no point in arguing, but look at this senario. We all have seen this. Not that it has ever happend to you, but to the average homeowner who really has no business being in the panel, as many HOME owners dont make good connections, etc. There are lots of wires in the panel, so you have a tough time putting the cover on.
The wire nut comes off one of the neutral wires you have extended. With the jostling of the wires, that neutral accidently finds it way to a hot point in the panel. You now have a 240 volt circuit. Yes, it would be rare to happen, but for this reason making connections in a panel is a bad idea. NEC allows it, CSA does not.
So what does a Canadian do when he changes out a panel and some of the wires are too short? A bunch of j-boxes?
By the way tonyf, you didn't simply say it was a CEC violation, you said it was "very unsafe". Sometimes, they are not synonymous. I'm curious as to why you consider it such. I know you won't answer, because you have made up your mind, but I'm curious.
Tony, this is far from an argument. it is a decent discussion so far.
I see your point, but your "what if..." scenarios could be used in many different settings or situations. I think we just fail to see how this is any more unsafe than 100 other things.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
