Splicing Inside A Sub-panel - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2007, 07:35 PM   #1
Splicing inside a sub-panel
Is it code to splice a couple of wires together in a sub-panel using wire nuts? I have a short 12/2 wire I need to make a tad longer (won't reach the bus-bar). If not I'll have to re-wire to the next availiable recepticale, just thought splicing in the panel box would be easier as long as it's code. Can't see why it wouldn't be ok, but then I know just enough to be dangerous.
Thanks for any help.
Sean
SeanR is offline   Reply With Quote
Old 10-13-2007, 07:49 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
It is perfectly fine to do that.
Old 10-13-2007, 08:10 PM   #3
Electrician
Yes, your allowed to splice inside a panel...
chris75 is offline   Reply With Quote
Old 10-13-2007, 08:46 PM   #4
Electrician philosopher
Go ahead and turn that sub panel off as well while you are working on it. As luck would have it, today a ground slipped out of my hand and in slow motion grazed the buss bar...no harm, no foul...but still definitely not cool. They don't call us sparkies for nothin'. The panel was in a lab and the minor pop had me surrounded by the white coats quick.
Andy in ATL is offline   Reply With Quote
Old 10-13-2007, 08:49 PM   #5
There wasn't a padded room involved, was there?
Old 10-13-2007, 09:01 PM   #6
No, but it was first thing in the morning, changing a 20A breaker in a 120/208V panel. Minor slippage, minor poppage, minor sparkage and all of a sudden every one wants to know what the electrician is doing.
Old 10-13-2007, 09:14 PM   #7
Mucho Grasia Guys,
Andy, yes, power from the main is off.
So, that's two sparks Andy. Something about the "third time is the ..."
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
Wiring 100A subpanel nebulous Electrical 9 08-29-2007 03:41 PM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 01:58 PM
Subpanel over Water JPsAlias Electrical 13 06-05-2007 11:16 PM
