Old 06-02-2010, 12:35 PM   #1
I=E/R
a7ecorsair's Avatar
Splicing of direct bury aluminum cable
I will be tearing down my lake cabin and building a year around house. My detached garage power is a service lateral from the house meter with 2-4-2 aluminum. My power company no longer allows meters to be attached to the dwelling and they place a meter socket a minimum of 50' from the structure. My problem is that the garage service lateral cable will not reach the new meter - it will be 20 feet short. I've been looking to see what is available to do a direct bury splice but I haven't found much. GB has a splice but the catalog says it is for copper. Grainger shows an epoxy kit that is used with a splice but it looks like each kit is enough for one splice and the kit is $35.
What else is out there for splicing or will I have to dig up the cable all the way back to the garage and lay new cable? I'm just looking for the easiest way.
a7ecorsair is offline   Reply With Quote
Old 06-02-2010, 12:40 PM   #2
Xtreme DIY'r
Have you asked them if they will place the meter within reach of the old cable ?
Old 06-02-2010, 12:54 PM   #3
Master Electrician
Splice kits are available for directly buried Al cables. These splices must be done correctly as any migration of moisture will quickly destroy Al conductors
You'll probably need to go to an electrical supply house.
brric is offline   Reply With Quote
Old 06-02-2010, 01:00 PM   #4
I=E/R
a7ecorsair's Avatar
Thanks for the replies.
An asphalt driveway and septic system are in the way of placing the meter closer.
Isn't Grainger a supply house? They sure have just about everything.
Old 06-02-2010, 01:50 PM   #5
Master Electrician
Not if you can't get what you need.
Splicing Aluminum to Copper Wire dc4nomore Electrical 28 05-08-2012 02:56 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 10:10 AM
#6 aluminum cable penticton Electrical 26 03-11-2009 09:48 PM
Wiring my garage with direct burial cable? Earl Smith Electrical 3 08-10-2008 07:28 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
