Splicing Branch Circuit In Junction Box Question - Electrical - DIY Chatroom Home Improvement Forum
Old 04-26-2014, 10:10 AM   #1
Splicing Branch Circuit in Junction Box Question
I'm working on a basement finishing project. I have a smoke alarm in my unfinished basement. I'd really like to move it, but it's the first alarm on the circuit, and the other smoke detectors in the house receive power from it. I cannot replace this existing 14-3 wire that feeds the other smoke detectors, as it goes right up through the floor above and into the rest of the house.
I've mounted a can light nearby that's rated for 8 12awg through conductors, and the existing 14-3 wire could reach it easily. The junction box already has two 14-2 wires in it--one feeding the light and one feeding the next light in the chain--as well as the wires built into the fixture.
My question: Can I splice the smoke alarm branch circuit within the can light junction box? Would this be within code?
Thanks!
clegane is offline   Reply With Quote
Old 04-26-2014, 01:27 PM   #2
Rewards Points: 808
Thanks!
No. You already have 2 x 14/2 for the light. You'd need to put another 14/2 - the feed for the smoke alarms, and the 14/3, the feed to the rest of the smoke alarms, PLUS another 14/3, a feed for wherever you're relocating the existing smoke alarm. You're better off just making that splice within a regular ceiling box, and finish it off with a blank cover on the ceiling.
IslandGuy is offline   Reply With Quote
Old 04-26-2014, 02:05 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Generally the can housing slides out of the frame in kit, if so.... I would have no issues to have a separate j-box above this location for the smokes that is still accessible with the removal of the recess can.
Old 04-26-2014, 03:58 PM   #4
Rewards Points: 3,396
Great solution. Although it always confused me that unless you knew it was there you wouldn't know it was there
All the best with it.
Phil.
ritelec is offline   Reply With Quote
Old 04-26-2014, 04:48 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Phil.
I was right, it is UnclePhi l
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
HouseHelper (04-26-2014)
Old 04-26-2014, 10:36 PM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,460
To quote a friend of mine from another forum......
"And yes, I'm not afraid to admit I like Mike Holmes" and UncP.
RJ....He brings color, ya gotta admit.
Best
MTN REMODEL LLC is online now   Reply With Quote
Old 04-27-2014, 12:12 AM   #7
E2 Electrician
Great solution. Although it always confused me that unless you knew it was there you wouldn't know it was there All the best with it. Phil.
No different than any other junction box.
Old 04-27-2014, 05:11 AM   #8
A "Handy Husband"
rjniles's Avatar
Best
Not all of us do/did. His rants became confusing to less knowledgeable posters, he relied on some memory of how he used to do it and gave a wink & a nod to violating NEC code. Maybe more than a wink & a nod; openly encouraging violations.
Old 04-27-2014, 08:42 AM   #9
Well... I guess I did not see him as bad intentioned.... but I do see how you arrived at, and do respect your take/opinion.
Old 04-27-2014, 12:47 PM   #10
Edit. Had something to say about burying a splice behind a downlight or wall. But then figured out whatever I said wouldn't turn into a healthy discussion.
Enjoy this beautiful day all.
Tags
splicing branch circuits
Replacing Cooktop, Circuit Amperage Question diverdave Electrical 23 07-20-2013 10:54 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 03:10 PM
Arc Fault Break Tripping when any light switch turned on elab1 Electrical 60 11-20-2009 02:24 PM
Splicing on 6 gauge wire paxprobellum Electrical 58 08-29-2009 02:22 AM
