Splicing Aluminum Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 02-23-2011, 03:17 PM   #1
I have to run three 220-foot lengths of #1 aluminum cable through electrical conduit underground. I will need to order and buy a five hundred foot spool, as the local dealer does not stock this wire. He will have to order a full spool and he will not sell just the length I need. That means I would end up with two 220-foot lengths and have a shorter 160-foot piece left. I have sevearl lengths about 30 foot each aleady. Can I splice the 160 piece with another piece to make up the 220 foot and use it with the other two in the conduit? What kind of splicer would I need to use? Is there a possibility it may separate under ground and cause problems later?
DAlnB is offline   Reply With Quote
Old 02-23-2011, 03:27 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
You can splice the wire, but you can not splice it inside the conduit.
It must be spliced inside a junction box of the right size.
Old 02-23-2011, 04:22 PM   #3
iminaquagmire's Avatar
Rewards Points: 338
Keep in mind also that the boxes have to be accessible. You cannot bury the box with the conduit. It would have to be stubbed up above ground.
iminaquagmire is offline   Reply With Quote
Old 02-23-2011, 05:35 PM   #4
Rewards Points: 1,214
Buy 2 spools and try to sell the remaining don't splice your only looking for trouble. Check your math.
COLDIRON is offline   Reply With Quote
Old 02-23-2011, 05:54 PM   #5
Master Electrician
Rewards Points: 3,678
find another supplier.
brric is offline   Reply With Quote
The Following 2 Users Say Thank You to brric For This Useful Post:
Charlie K. (02-23-2011), Speedy Petey (02-23-2011)
Old 02-23-2011, 06:15 PM   #6
Yeah I was tempted to post that.
Old 02-24-2011, 02:07 AM   #7
Scared Electrician
Saturday Cowboy's Avatar
might be cheaper to go with #3copper
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 02-24-2011, 02:26 AM   #8
" Euro " electrician
frenchelectrican's Avatar
If this is in the conduit and what the actual conduit run lengthwise ?
you should come pretty close to that number and #1 alum cable you can check with other supplier some case they will stock a thousand foot spool and cut to that length { some case it will be cheaper this route due you use pretty good part of larger spools }
And with conduits you do not make any splices in the conduit unless you have juction boxes avabile for it.
Really I rather keep the numbers of spices to the minuim as possible ( less things can go wrong on it )
Merci.
Marc
Old 02-24-2011, 05:10 AM   #9
Rewards Points: 712
I was thinking the same thing. Aluminum is rarely much cheaper in the smaller sizes.
Mark
busman is offline   Reply With Quote
Splicing Aluminum to Copper Wire dc4nomore Electrical 28 05-08-2012 02:56 PM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 09:21 PM
Splicing of direct bury aluminum cable a7ecorsair Electrical 4 06-02-2010 01:50 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 10:10 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
