Splicing 9-5kv Conductors In One Splice Box - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2011, 09:19 AM   #1
Splicing 9-5kv conductors in one splice box
I have 3-250's, 3-350's and 3-500's medium voltage cables to splice in one nema 4x box. What are the dimensions for the splice box?
j_mahan is offline   Reply With Quote
Old 09-01-2011, 09:36 AM   #2
Rewards Points: 6,652
Need to do your own homework.
The Following 2 Users Say Thank You to gregzoll For This Useful Post:
SD515 (09-01-2011), Speedy Petey (09-01-2011)
Old 09-01-2011, 09:37 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
Hint...See Atricle 314, Part IV.
Kyle
Old 09-01-2011, 10:17 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,184
Not close to a DIY project.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Old 09-01-2011, 10:52 AM   #5
Rewards Points: 126
Hes doing homework or it's a test he is taking and wants the easy answer.
The Following User Says Thank You to J. V. For This Useful Post:
SD515 (09-01-2011)
Old 09-01-2011, 10:58 AM   #6
Electrician
SD515's Avatar
Rewards Points: 504
Sure it is. Homework is almost always a DIY project.
Kyle
Old 09-01-2011, 11:19 AM   #7
The answer is, that it is bigger than a bread box, but smaller than a VW.
Old 09-01-2011, 11:25 AM   #8
" Euro " electrician
frenchelectrican's Avatar
If this is the homework type I can not do much with it but if you are legit electrician you should talk to other electricians whom they deal with high voltage stuff and by the way.,
You did not stated what type of MV cable it is., so I will not able give you a driect answer to it due there is many types of MV cables to deal wiht it and the last thing is this is NOT A DIY item anyway.
Merci,
Marc
Confusion over how many conductors in an electrical box dharper Electrical 11 07-08-2011 07:43 AM
Splice conductors in wet location whatrymes Electrical 10 04-28-2011 09:37 PM
Help splicing many conductors whatrymes Electrical 12 04-10-2011 11:36 AM
Splicing of direct bury aluminum cable a7ecorsair Electrical 4 06-02-2010 12:50 PM
NEC Junction Box Conductor FIll: A Single Splice is counted as Two Conductors? Lovegasoline Electrical 7 12-02-2009 10:44 PM
