Splicer Large Conductors - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2013, 07:17 PM   #1
langless28's Avatar
Rewards Points: 152
Splicer large conductors
I am running 6/3 nm-b to a 6x6x4 pvc junction box which connects to my pvc conduit with thhn wires to my garage for a new subpanel. Is it best practice to use "splicer reducers" covered in heat shrink for the thhn to Romex connections? I also need to get a grounding bushing for the metal nm-b clamp and tie that to the grounds correct?
langless28 is offline   Reply With Quote
Old 06-10-2013, 07:37 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by langless28 View Post
I am running 6/3 nm-b...
A couple of #6's will be fine with (big) wirenuts. How many are you joining?
Do I also need to get a grounding bushing for the metal nm-b clamp and tie that to the grounds correct?
Really not sure what you mean here.
Old 06-10-2013, 07:47 PM   #3
langless28's Avatar
Rewards Points: 152
Just a 4 wire setup.
I am using a metal nm-b clamp on a plastic box, and I'm prettier sure that needs to be grounded.
Old 06-10-2013, 08:43 PM   #4
Master Electrician
Rewards Points: 3,918
I've never bonded an nm connector in 30 years. Use a bonding bushing if it makes you feel better.
brric is online now   Reply With Quote
Old 06-10-2013, 09:09 PM   #5
langless28's Avatar
Rewards Points: 152
I thougt it was required..... A piece of metal in and out of a box....
Anyway I'm more concerned about the splicing.
Old 06-10-2013, 09:23 PM   #6
Licensed electrician
Rewards Points: 1,766
If you are just splicing 2 #6's you can use the large blue wire nuts.
No need to use a bonding locknut.
Old 06-11-2013, 07:58 AM   #7
Rewards Points: 3,130
You could also use split bolts, but the big blues are probably cheaper.
Common Neutral in Jct Box??? PastorKramer Electrical 5 11-20-2012 06:10 AM
Large Mulch bed under maple trees questions Leah Frances Landscaping & Lawn Care 2 04-19-2011 09:44 PM
dimming lights from large geothermal heat pump atuel Electrical 65 01-14-2011 04:16 AM
Unused large central closet to become Laundry room. Soupcatcher Plumbing 1 08-06-2010 04:01 AM
Retaining wall near very old maple (large roots) hokietoner Landscaping & Lawn Care 1 04-19-2010 10:21 AM
