Splice And Using Lug In Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2010, 10:25 AM   #1
splice and using lug in panel
I have short wire length in 400amp panel from main MDP
Can I use lug between short wire to terminal at about 4feet inside panel?
hammer.j is offline   Reply With Quote
Old 12-17-2010, 10:38 AM   #2
Licensed electrician
Rewards Points: 1,892
A lug is designed to terminate a conductor, not splice. I suggest that you get someone qualified ro more knowledgeable to assist you, especially in a 400 amp panel. A panel that size is not a DIY item.
