Splice An Underground Wire For Light Post - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 10:21 AM   #1
Rewards Points: 79
Splice an Underground wire for light post
A few months ago we had a new walkway installed. They cut the wire that goes from the house to the light post in our front yard. The "fixed" it and buried it under the walkway, but they must have just used duct tape to splice the wires. Now the light isn't working so I'm guessing that their "fix" has failed over time.
My possible solution:
Cut the wire on both sides of the walkway, splice in a new longer piece of wire so that I can run it around the walkway, use heat-shrink tubing over the splice and re-bury the wire.
Should this work?
rpearlberg is offline   Reply With Quote
Old 11-15-2011, 10:27 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
They make underground splice kits.
You can find them at Lowes or HD.
HD, Danger Mouse'e favorite place to shop!
The Following User Says Thank You to jbfan For This Useful Post:
rpearlberg (11-15-2011)
Old 11-15-2011, 10:31 AM   #3
Rewards Points: 79
I got the parts last night at HD. Can I use a hair dryer for the heat-shrink, or do I get to buy a heat torch?
Old 11-15-2011, 10:38 AM   #4
jbfan's Avatar
Rewards Points: 546
Yes, a hairdryer will work.
Old 11-15-2011, 10:39 AM   #5
Rewards Points: 79
Thanks. It's raining for the next couple of days so I'll give it a shot this weekend. I spent $30 on materials, hoping to save the $100-$150 I was quoted by an electrician....(at a minimum).
Old 11-15-2011, 11:37 AM   #6
Rewards Points: 768
a hair dryer may not work very good, some shrink tubing need at least 200F air. i always use heat gun or torch for those use
carmusic is offline   Reply With Quote
Old 11-15-2011, 05:07 PM   #7
Semi-Pro Electro-Geek
Rewards Points: 2,970
Heat gun, torch, lighter, matches, whatever. A hair dryer probably won't get hot enough. It's very important to fully heat the connection, since those splice kits rely on melting a sealant inside the shrink tube to ensure waterproofing. Err on the side of too much heat.
mpoulton is offline   Reply With Quote
Old 11-15-2011, 11:17 PM   #8
What you need is a 3m resin kitFor The Underground splice
kleakak is offline   Reply With Quote
Old 11-16-2011, 06:37 AM   #9
Rewards Points: 1,216
They should be in a box and a drawing of the location in reference to the placement that is put away in your house and yard file just in case you die or move there will be a record of where this splice is.
COLDIRON is offline   Reply With Quote
Old 11-16-2011, 06:55 AM   #10
Most boxes are not rated for direct buriel,
Old 11-16-2011, 07:02 AM   #11
This is absolutely incorrect. You do not burry boxes and make treasure maps to find them. Use a rated underground splice kit and follow the instructions.
Colomboj is offline   Reply With Quote
Old 11-16-2011, 08:01 AM   #12
Ok thanks on the boxes but I still think the location of the splice should be drawn on a yard map with measurements to pinpoint where the splice is in case there's a problem later. It's called an as-built drawing after the work is done. It can be placed where the circuit starts or in a file that you should keep on your property.
Old 11-16-2011, 08:03 AM   #13
Burial.
Old 11-16-2011, 08:05 AM   #14
Their not called treasure maps their called as-built drawings. Bury.
Old 11-16-2011, 09:35 AM   #15
Now we are talking about a damn yard lamp here not a high voltage feeder to a pmh in your back yard. In other words no reasonable human keeps freaking as builds of their home.
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
can i splice the wire together bulldog75 Electrical 14 08-23-2011 02:43 PM
Question about underground wire type Tmb9862 Electrical 9 11-26-2009 10:35 AM
Looking to splice a 150 amp wire correctly. nebruin Electrical 10 10-20-2009 07:23 PM
