To Splice Or Not To Splice - Electrical - DIY Chatroom Home Improvement Forum
Old 01-19-2008, 06:13 PM   #1
to splice or not to splice
I am trying to repair a kitchen that has suffered a fire. upon inspection of the outlets, I found some charing and discoloration on the rollmex wireing. The big question is can I cut off the damaged area and splice in a 1ft section?? Is this normal and will this pass city codes?? What would you do?? thanks
treedoc is offline   Reply With Quote
Old 01-19-2008, 06:33 PM   #2
Splice ONLY in an ACCESSIBLE jbox.
220/221 is offline   Reply With Quote
Old 01-19-2008, 07:32 PM   #3
joed's Avatar
Rewards Points: 13,766
All splices must be in accessible junction boxes. Unless you want another box with a blank cover on the wall replace the cable back to a place where you can install a junction box that not be visible in the kitchen.
Old 01-19-2008, 09:12 PM   #4
Res Ipsa Loquitur
As said before only in an accessible J-box although I might try to go back to an existing box and replace romex back to that one. It would depend how far you have to go to determine if it is worth it.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 01-19-2008, 10:56 PM   #5
Ok, sounds like a plan. Thanks for the help!!
Max number of wires you can splice together firemanpato Electrical 12 01-10-2008 06:46 PM
Splice triplex line??????? klaaar Electrical 15 11-26-2007 09:58 PM
Splice box/s between subpanel and main panel? SeanR Electrical 5 05-06-2007 02:21 PM
Underground cabling splice question rnichols Electrical 3 10-24-2006 09:40 AM
14 guage splice into 20 amp 12 guage circuit OK Bakes5 Electrical 3 12-19-2005 08:41 PM
