Old 04-28-2011, 09:21 PM   #1
Splice conductors in wet location
I'm ready to start my outside project which consists of a GFCI receptacle, a pair of flood lights and a switch using pvc and weather tight boxes. I paid all kinds of attention to getting the correct conductors (UF, THWN) and equipment but didn't even consider my splices. I was planing on basic wire nuts, "greenies" and some Ideal In-Sure connectors. Am I OK??
Thank you,
Ed
whatrymes is offline   Reply With Quote
Old 04-28-2011, 09:28 PM   #2
Licensed electrician
An inspector told me a recent code change was that splicing materials used in wet areas needed to be rated for the environment and regular wire nuts could not be used any longer. I don't know about about the In-sure push-ins.
Old 04-28-2011, 09:32 PM   #3
nap
You talking to me?
nap's Avatar
You can usually do one of a couple things:
1. put in a hand hole or ground box and make the joints in there. You will need to have connectors rated for wet conditions. They make wire nuts filled with silicone goo that work
2. use an underground splice kit. They are designed to be used as direct burial.
Your proposed method will work only if you put the splice in a waterproof box. Even then I tend to use the silicone filled wirenuts. It never remains as dry as you want it to.
Old 04-28-2011, 09:36 PM   #4
None of the splices are under ground, they are all on a wall in different boxes.
Old 04-28-2011, 09:45 PM   #5
If you are using standard wire nuts, it's a good idea to fill each wire nut with a little bit of silicone before twisting them on. Then, tape the wire nut and position them in the box so they are " upright" and won't hold condensation.
Abcanfield is offline   Reply With Quote
Old 04-28-2011, 09:56 PM   #6
nap
You talking to me?
nap's Avatar
what kind of boxes?
Is this in conduit?
Old 04-28-2011, 10:03 PM   #7
Originally Posted by nap View Post
what kind of boxes?
Is this in conduit?
The boxes are the kit sold at electrical supply stores. My 2 gang box is made by "Red dot". They are metal, have threaded holes for conduit and knockout plugs and gaskets.
I am using PVC conduit to run THWN out the house and up a pipe to the flood lights.
Then UF will head to the shed for some more lights and receptacles.
Old 04-28-2011, 10:07 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Then none of them are in a wet location.
The boxes are, but the splices are NOT.
Speedy Petey is online now   Reply With Quote
Old 04-28-2011, 10:15 PM   #9
nap
You talking to me?
nap's Avatar
in that situation, what you have will work. For some reason I thought you were splicing underground. I still prefer silicone filled nuts. There is usually enough dampness to cause some corrosion.
Old 04-28-2011, 10:23 PM   #10
I just noticed that the In-Sure push-ins say "For dry locations only." Would inside the box be a "Dry" location?
Thanks again
Old 04-28-2011, 10:37 PM   #11
Yup, that's exactly what I said.
GFCI and grounded conductors whatrymes Electrical 7 04-18-2011 09:58 PM
Help splicing many conductors whatrymes Electrical 12 04-10-2011 12:36 PM
Encourage people to list their location secutanudu Site Help and Suggestions 0 09-15-2010 09:03 AM
Marking buried cable a7ecorsair Electrical 15 07-20-2010 01:27 AM
NEC Junction Box Conductor FIll: A Single Splice is counted as Two Conductors? Lovegasoline Electrical 7 12-02-2009 11:44 PM
