Splice In Breaker Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-22-2012, 04:22 PM   #16
Rewards Points: 1,514
Two wires can go under one screw only when there are grooves or a "cap" washer that hold both wires completely under the screw head before the screw has been fully tightened. The wires do not criss cross or go one atop the other.
Old 12-22-2012, 05:01 PM   #17
Rewards Points: 20
OK, so at least in my CH panel I can run out of holes in the neutral and ground bars (which have no grooves or cap washers for multiple wires per hole) before I run out of breakers I can tie into. So what are considered best practices for adding more bonding points for neutral and ground wires?
dbooksta is offline   Reply With Quote
Old 12-22-2012, 05:50 PM   #18
Rewards Points: 150
Please disregard, see Post #20 below.
Take the neutrals from two circuits, and wire nut them together along with a short (6-12" should be enough*) piece of wire (called a "pigtail"). Put the other end of the pigtail in the hole in the neutral bar.
Since the pigtail will be carrying the current from two circuits, it should be a larger gauge (smaller number) than the hot wires for that circuit, since in the worst case, it will be carrying the total current of both circuits.
*You want the pigtail to be long enough to go from its location after it is wire-nutted to the screw holes in the neutral bar.
Use the same method with the ground wires.
Dave632 is offline   Reply With Quote
Old 12-22-2012, 05:54 PM   #19
Licensed electrician
Rewards Points: 1,634
I feel a better solution is just to add an additional ground bar. Move the grounds to this new bar and free up the holes for the neutrals. No chance to have an overloaded neutral, even if upsized.
dbooksta (12-23-2012)
Old 12-22-2012, 05:55 PM   #20
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
This is NOT legal.
The Following User Says Thank You to k_buz For This Useful Post:
breaker panel Ehren51 Electrical 3 01-20-2015 05:23 PM
neutral wire splice in breaker panel joelowrider Electrical 24 02-23-2012 01:02 PM
Temporarily feeding a sub panel with 10-3 30 amp breaker rrolleston Electrical 6 02-23-2012 09:40 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
