Splice Behind Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-28-2011, 06:13 PM   #1
Rewards Points: 27
Splice behind wall?
Is there any way to splice a cable (14-2) behind a wall and leave it concealed? I understand that junction boxes should always be accessible. Any way around this?
Eric
mn1247 is offline   Reply With Quote
Old 09-28-2011, 06:18 PM   #2
Licensed electrician
Rewards Points: 996
there is no code legal way to have the splice buried in the wall.
The Following 5 Users Say Thank You to Jim Port For This Useful Post:
frenchelectrican (09-29-2011), gregzoll (09-29-2011), oh'mike (09-30-2011), SD515 (09-29-2011), whatsup (10-01-2011)
Old 09-29-2011, 02:41 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Eric
Nope., not with standard items and with any junction box it have to be accessable to it.
And I am not crazy with hidden splices and hidden junction box I just have one not too long ago in France 30 hidden junction boxes took me not super long to find it all of it.[ Half day in first floor and other half day on second floor ]
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
SD515 (09-29-2011)
Old 09-29-2011, 06:23 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
The job I'm currently working on is a complete re-wire. A fire started in the attic due to a hidden splice joint.
Kyle
The Following 2 Users Say Thank You to SD515 For This Useful Post:
Old 09-29-2011, 06:31 AM   #5
Lic Elect/Inspector/CPO
Amp makes a product to splice for 14/2, 14/3, 12/2, 12/3 without a junction box.
The product does comply with 330.24(b)
B) Devices of Insulating Material.
Switch, outlet, and tap devices of insulating material shall be permitted to be used without boxes in exposed cable wiring and for rewiring in existing buildings where the cable is concealed and fished. Openings in such devices shall form a close fit around the outer covering of the cable, and the device shall fully enclose the part of the cable from which any part of the covering has been removed. Where connections to conductors are by binding-screw terminals, there shall be available as many terminals as conductors.
NJMarine is offline   Reply With Quote
The Following User Says Thank You to NJMarine For This Useful Post:
SD515 (09-29-2011)
Old 09-30-2011, 02:48 PM   #6
NJMarine , would this work as well - found it @HD site:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
and this is legal in NJ, right?
legende is offline   Reply With Quote
Old 09-30-2011, 06:51 PM   #7
Yes that will work. Make sure you put the correct wires in the right slots. I also put tape around it, but that is my way.
I have used them many times and have never failed an inspection for using them. I would pass it, because it is aproved and meets the code.
Old 09-30-2011, 07:22 PM   #8
Code05's Avatar
Rewards Points: 1,104
That thing is listed for trailer connections. It is not a substitute for a box in standard wiring that I know of.
Code05 is offline   Reply With Quote
Old 09-30-2011, 08:43 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 782
Legal or not legal....the thing to remember is....everywhere you have a connection....you have a potential for a bad connection....and a fire.....
Wire is cheap....especially when compared to the potential consequences.........
I'm in the middle of a 2-story addition to my house....I have a lot of work connecting my existing wiring to the new panel....In one case, I will have to replace about 30' of romex so that I don't have to use a junction box. Yea, I know, some guys would say..."Just put in the box and connect it there". I could....but I intend to be here a long time....I actually like my wife and kids....I travel a lot....I do not want to have to worry about the wiring....
As they say, never enough time to do it right, but always enough time to do it over.....
Wire is cheap.....
Old 09-30-2011, 09:20 PM   #10
Rewards Points: 266
Those Tyco trailer house connectors are junk. They rely in insulation piercing connections that have very little contact area and will fail eventually.
I would be creative and figure out a way to run new wire so you don't need a box. People come on here all the time and say that it is "impossible to run new wire" in their case, but anything is possible.
junkcollector is offline   Reply With Quote
Old 10-01-2011, 03:20 AM   #11
NJMarine.,
I have see that kind connectors before on the moble home that is the most common item I have see for that useage espcally with double wide they use that to join together for compleated circuit and many time I have got few service call from that item due they will fail in few years and have to resort to proper juction box and spice it with wirenuts and slove the issue with it.
I know they are used few spots in resdentail home but again that is pretty limited { I know the last time the inspector in Wisconsin did not allow it in the regular resdentail home at all so AFAIK that may change }
Merci,
Marc
Old 10-01-2011, 05:43 AM   #12
Thanks a lot NJMarine! Now I can use these 2 good spare lengths of 14-2 that would've gone wasted and return the 50' I just purchased to HD.
But, I guess the others have reservations about it , now that I just read them. Maybe be safe than sorry.
Last edited by legende; 10-01-2011 at 05:47 AM. Reason: accounting for others' opinions
Old 10-01-2011, 07:55 AM   #13
These splices have a purpose. I use them when I cannot run a new wire . Such as when front light sconces need to be moved over and the romex is not long enough.
Old 10-01-2011, 08:04 AM   #14
Rewards Points: 150
Yuuuup. +1
OhioHomeDoctor is offline   Reply With Quote
Old 10-01-2011, 08:21 AM   #15
Rewards Points: 1,418
Knob and tube is not legal but a soldered knob and tube T joint is much safer and longer lasting than a gizmo with a push-in-and-it-sticks connection or an insulation piercing connection. THe latter does not belong buried in a wall, legal or not. It can be used for situations such as a light fixture mounted on a wall with no box behind it.
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 02:35 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
