Splice 3wire Cable Run With Nicked Insulation - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2010, 01:59 AM   #1
Splice 3wire cable run with nicked insulation
Hello - first time in chat room so please bear with any messaging protocol problems - they are unintentional
I am located in Ottawa ON. I have a cable run of about 50' from distribution panel to a switched outlet most of which is routed through the attic and is stapled in position on existing or newly introduced 2x4 beams in the attic. The insulation of the cable in the attic was accidentally nicked in the attic just as it looped through the ceiling approx 12" from the switched outlet cable end. The insulation in the attic is blown about 1' deep coverage. Can I install a junction box (properly fastened to a beam at 16" above attic ceiling) where the nick is located and splice the wiring in order to avoid rerunning the entire cable length?
ARC&SPARK is offline   Reply With Quote
Old 11-30-2010, 04:31 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
Yes you can do as you suggest. But if the nick is only in the outer jacket of the cable and not in the insulation of an individual wire, you can tape up with electrical tape.
Coastal South Carolina
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 07:17 AM
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 08:00 AM
cable splice kit instead of juction box? pat72 Electrical 18 07-21-2008 05:12 PM
What's the best way to splice 1/0 cable? Randell Tarin Electrical 30 02-01-2008 02:38 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
