Specialized Termination Bars? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2008, 09:30 AM   #1
HYPOTHETICAL SITUATION:
There is a MAIN panel from which a subpanel will be feed by a unspecified large conductor (range #4-1/0) .
The MAIN panel has but one termination bar to which both neutral and ground are terminated. However, the holes that are available to receive the wire appear only large enough to receive up to a #6 or #8 conductor.
QUESTIONS:
How does one go about terminating the neutral on the larger feed conductor?
Would you use a supplementary bar with larger lugs and a bonding strap to the neutral bar?
If so, because the NEUTRAL and GROUND are bonded in the panel case, can this new bar be attached directly to the case?
Randell Tarin is offline   Reply With Quote
Old 02-20-2008, 11:27 AM   #2
Rewards Points: 2,350
QUESTIONS:
Lugs are manufactured for the purpose of attaching to an existing bar. I have also seen, but do not recommend, the individual strands of a conductor separated into bundles small enough to fit under a couple of different screws on a bar.
As far as terminating a neutral on the case of a panel, don't do it. It is a hack job at best. The neutral current would rely on the panel for continuity.
InPhase277
Old 02-20-2008, 02:01 PM   #3
So do these lugs physically attach to the neutral bar or do they have a bonding strap that connects them?
Old 02-20-2008, 02:29 PM   #4
Are these what your asking about?
http://contractorservices.homedepot....a-02cd3db11ccc
http://www.drillspot.com/products/52...AN_Neutral_Lug
jerryh3 is offline   Reply With Quote
Old 02-20-2008, 03:27 PM   #5
So, how is this attached to the neutral bar?
And are lugs of this type panel specific, i.e. Square D for Square D or Siemens to Siemens?
Old 02-20-2008, 03:46 PM   #6
The two little spades are inserted into two adjacent screw holes. I believe they are brand specific.
Old 02-20-2008, 04:38 PM   #7
Thanks dude. This is good info.
Crown molding termination at tile Stickboy Carpentry 4 12-26-2011 10:35 PM
Repairing Futon metal bars? mikehende General DIY Discussions 9 01-24-2008 09:04 AM
2 Ground Bars in sub panel Paul_D Electrical 5 06-14-2007 09:25 PM
