Speaker Wire In Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 03:51 PM   #1
Speaker wire in conduit
Hi folks,
Question first: is it generally code legal to put speaker wire in the same conduit that has line voltage? (I realize it's not an ideal practice and can cause hum/interference...)
Sitation: a few years back we built a pergola outdoors and ran electrical to the top to power an outdoor ceiling fan/light. Work was done by a licensed electrician and put in proper conduit.
The tricky part was running up one of the pergola legs. We thought ahead (but not far enough, apparently ) by notching the 6x6 post and embedding the conduit, which was then clad with cedar and stone, and of course the patio fieldstone floor surrounding it.
I'd like to put speakers up there too, but that means getting speaker wire to the top of the pergola. There's no good way to do this without serious destruction or ugly conduit run outside the stone accents.
While I realize it's not generally a great idea to run the cables in parallel, I wanted to see if it was generally (I'm in NC) code legal to do so?
If it is code legal, I figure it's worth trying before resorting to some tear down.
Thanks much!
bhnc is offline   Reply With Quote
Old 08-06-2011, 04:36 PM   #2
numerous companies make wireless speakers. try tigerdirect or newegg. the only thing they need is power. some even run on batteries or ac adapter. they also have the speakers that look like a big rock for outdoors.
Old 08-06-2011, 04:54 PM   #3
wareagle's Avatar
Originally Posted by bhnc View Post
Hi folks,
Thanks much!
Absoutly not.
wareagle is offline   Reply With Quote
Old 08-06-2011, 04:57 PM   #4
Thx -- yeah it's already part of a Sonos system. I have a few alternatives mapped out with where to put some of the components (including some varients, like the "rock speakers") but the ideal (from an audio quality, ease of use, cost, ease of installation) would require colocating the speaker cable in that conduit.
In searching the net for this answer, it looked like some felt not allowed, others though it was as long as the cable was properly rated.
I'm under the assumption it's not allowed, but figured I'd ask.
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Question about outdoor panel, conduit and derating wire pttcc Electrical 10 02-15-2010 11:51 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
driving wire through buried conduit amakarevic Electrical 26 07-08-2009 07:48 PM
ground wire in rigid conduit measure thrice Electrical 3 02-03-2009 06:25 AM
