SPD In Distribution - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 07:48 AM   #1
SPD in Distribution
hello
can anyone take a look at the attached setup and advice if it was correctly connected?
also, why is there no cable at the PE point on the SPD?
udamico is offline   Reply With Quote
Old 03-07-2011, 09:34 AM   #2
Electrician Canadian Eh!!
Read the manufacturer's instructions as they will only warranty if it meets their approved methods.
Generally surge protection is in parallel to load.
The PE terminal is for monitoring purposes. Think industrial setting with manufacturing. They want to shut down equipment if anything goes wrong.
hhuggles is offline   Reply With Quote
Old 03-07-2011, 09:42 AM   #3
thanks for your update.
for PE, i understand and will disregard it...attached is the only manufacturer instructions i have.. i belive i am quite right, but i am not sure since logically setup is a little different.
Old 03-07-2011, 02:02 PM   #4
As per the manufacturers spec sheet, it IS wired in parallel to the load.
They show it off of the load center on its own breaker.
This is the same as I have wired many up.
Just wanted you to be confident that you were getting the right answers.
Old 03-08-2011, 01:25 AM   #5
thanks for that, im glad it was done correctly.
cheers
distribution methods help please Allthunbs Plumbing 0 12-16-2009 05:27 PM
uneven distribution of heat gt5966b HVAC 3 12-13-2009 11:02 AM
Low profile junction box or distribution block for line voltage undercabinet lights ? Bluelude1 Electrical 2 05-01-2008 07:52 PM
Copper pipe type for residential water distribution BigJimmy Plumbing 7 12-31-2007 08:39 AM
load distribution sporthead200369 Building & Construction 1 04-28-2007 08:54 PM
