Sparks From Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2013, 03:43 AM   #1
Sparks from Ceiling Fan
Hi All,
I put in a ceiling fan with light a few weeks back without any issue, but noticed I had connected it to the always hot wire as opposed to the switch wire, so last week I decided to disconnect the fan and set it up to the switch.
After connecting the fan and turning it on, I noted no issues. However, today when I turned on the fan, sparks came out of the fan and smoke followed. These sparks were short and the fan still runs as well as the light, but I'm not sure if I should be concerned of future sparks.
Does anyone know what might have caused this and if I should disassemble the fan again to check it out or if everything is OK?
Thanks in advance!
fmz65 is offline   Reply With Quote
Old 07-14-2013, 06:12 AM   #2
DIY Enthusiast
sublime2's Avatar
Yes!
To both questions.
Chances are you have a loose connection or/and a wire is touching the box.
sublime2 is offline   Reply With Quote
Old 07-14-2013, 08:07 AM   #3
Rewards Points: 446
Sparks AND smoke in the home and you are wondering? Seriously?
old_squid is offline   Reply With Quote
Old 07-14-2013, 11:34 AM   #4
Should I wrap the connections in electrical tape before/after I put the caps back on? Also, one of the wires is actually copper tubing of sort instead of the normal twisty wire.
Old 07-14-2013, 11:57 AM   #5
Wrap only after you have twisted the wirenut on. Not sure what you mean about copper tubing of sort. Must post pic.
guitarzan is offline   Reply With Quote
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 10:27 PM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 01:10 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
