Spark . Did Not Trip Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 11:50 PM   #1
Spark . did not trip breaker
Took a pair of plyers to reposition a open plug and got a spark... didn't trip the breaker but have lost power in frig and garage and more.. dont know what to do.
slahni is offline   Reply With Quote
Old 11-08-2012, 11:55 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
1st DO NOT do that again!
Kill the power to the outlet,make SURE power is off to it and then replace the receptacle.
sublime2 is offline   Reply With Quote
Old 11-08-2012, 11:58 PM   #3
Rewards Points: 13,296
Most likly a GFI has tripped. Just reset it.
Old 11-09-2012, 12:01 AM   #4
I will trip the breaker off and replace the recepticle and then trip the breaker back on...right? ??
Old 11-09-2012, 12:05 AM   #5
Is there a GFI? If so it's as simple as pushing a reset button.
http://www.elocalelectricians.com/co...gfi-outlet-576
Old 11-09-2012, 12:06 AM   #6
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Trip the breaker off,make SURE there is no power at the receptacle, then replace it and turn breaker back on.
Old 11-09-2012, 09:32 PM   #7
Well it didn't work. turned off power and replaced receptacle.. still no power. Checked each line in the Box and all have power to the breakers. How can u have power on the line and not have powe???r ...Cutler Hammer
Old 11-18-2012, 04:25 PM   #8
An old Tradesmen
Rewards Points: 6,544
Moved to electrical forum.
Old 11-18-2012, 04:27 PM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There could be any number of reasons.
I would first look for a GFI that has been tripped as has already been stated.
Old 11-18-2012, 04:30 PM   #10
Find the GFI outlet that is tripped and reset it.
You put a new rec in - Done
You checked your breakers - Done
G F I outlet needs to be reset
parman is offline   Reply With Quote
Old 11-18-2012, 04:54 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,124
As a side note.....using my in-laws house as an example.....I can not see any common sense as to how the builders ran GFI's.....the GFI for the garage is in an upstairs bathroom in the middle of the house....
ddawg16 is online now   Reply With Quote
Old 11-18-2012, 05:15 PM   #12
Tried everything then did a breaker test and found that the bottum plug in the kitchen went bad when the spark happened. .. fixed that and we have power. Only the bottum plugs...weird '-)
Old 11-18-2012, 05:15 PM   #13
Rewards Points: 1,442
Receptacles and sometimes switch boxes on the same circuit are daisy chained. It so happened that the first outlet box along the line was the one in the bathroom and they put the ground fault interrupter unit there and then continued the protected circuit from the GFCI load terminals to other outlet boxes including in the garage.
Receptacles and sometimes switch boxes on the same circuit are daisy chained. When you got the spark, it was a marginally loose connection in a different outlet box upstream that gave up the ghost. When incoming power is attached to one screw on the receptacle and power continuing to the next outlet box is attached to the screw right next to it, the tab that joins the screw pads (also joins the top and bottom halves of the duplex receptacle) happened to be where the failure took place. Plugging in and unplugging things at that receptacle may have weakened the tab physically. The tab is meant to be broken off when you want the top and bottom halves to be fed by different circuits,
Old 11-18-2012, 07:59 PM   #14
raylo32's Avatar
Rewards Points: 1,238
To reiterate: find the GFCI!! It can be in an illogical place like in my house. It's in the garage and feeds all the bathrooms on 2 upper floors and outside receptacles. Find yours and reset it. If it won't reset and you are sure that you fixed your problem, then replace the GFCI. They do fail on occassion.
Live long and prosper.
raylo32 is offline   Reply With Quote
GFI Breaker Won't Trip with tester nate456789 Electrical 31 03-25-2011 10:46 AM
Why would grounding a line trip the breaker? preciouschristy Electrical 11 02-26-2011 02:55 PM
Why did my breaker trip? yummy mummy Electrical 24 02-17-2010 11:38 PM
GFI breaker trip troubleshooting jeeptree10 Electrical 2 06-15-2008 11:17 AM
Breaker trip troubleshooting jeeptree10 General DIY Discussions 1 06-14-2008 04:00 PM
