Spark Connecting Ground On Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 09:38 PM   #1
Spark Connecting Ground on light fixture
Hello-
I have wired quite a few things in my days, but I have never seen this one.
I was wiring a large light fixture, connected hot, then neutral, then ground (I know that is the wrong order....ground should have been first).
When I went to connect the ground, I heard a large pop (like a firecracker) and saw a ton of sparks go flying.
I had the switch off, but it is on a timer and I was too slow to beat the timer, so it turned on just as I was connecting the ground.
This is a 3-way circuit with a Leviton 5-wire digital timer switch. This is a brand new house, so I have a neutral, hot, and ground - plus one additional wire for the 3-way.
However, up at the light, I just have a hot, neutral, and ground. There was a super cheap plastic fixture there before (like what you have in a garage closet) that only used the hot and neutral (ground was not connected).
Although the ground wires make a big bang with sparks when touched together, the light appears to work fine now (I turned off the switch, then finished wiring).
I don't want to run the light right now until I hear some thoughts on this. Don't want to burn the house down if this is a sign of trouble.
Does this maybe indicate that the hot or neutral wires could have a short that completed the circuit through this ground?
Thanks for your help!
Ron
RonaldD is offline   Reply With Quote
Old 01-08-2012, 10:10 PM   #2
MarginallyQualified
Rewards Points: 2,464
Learn your lesson?
Thoughts on what?
That is what meters are for. Check.
hth
Old 01-08-2012, 10:14 PM   #3
Never work anything hot.
Jdizzle is offline   Reply With Quote
Old 01-08-2012, 10:14 PM   #4
Missouri Bound's Avatar
...what's a garage closet?
Old 01-08-2012, 10:20 PM   #5
Keyless fixture!
Old 01-08-2012, 10:25 PM   #6
Originally Posted by Jdizzle View Post
Keyless fixture!
Oh I see...."garage / closet". Punctuation actually means something. You're pretty quick on the answers dizzle.....
Old 01-08-2012, 11:10 PM   #7
Julius793's Avatar
Use an amp meter to check if threre is any amperage on the ground. Spark should never be flying on the ground! Keep in mind if there's a ground fault doesn't have to be by that box it could be else where.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-09-2012, 03:57 AM   #8
dmxtothemax's Avatar
Rewards Points: 5,610
Whilst in an ideal world there should be no currents on the earth line,
How ever in real life, there quite often is currents.
Some times they are only low currents,
But best check it with a meter,
or even a test lamp.
dmxtothemax is offline   Reply With Quote
Old 01-09-2012, 07:23 AM   #9
Rewards Points: 1,548
With the two ground wire ends still separated, measure the voltage between them with the light switched on and again with the light switched off. Report back.
To see if the hot wires somewhere in the fixture are shorted to the frame of the fixture.
Old 01-09-2012, 07:33 AM   #10
joed's Avatar
Rewards Points: 13,768
Is this a metal box? Is the ground connected to the box?
Sounds like the hot wire is shorted. Either to the fixture or the box(if metal). Turn off the circuit (at the breaker not the switch) and use a meter to find the short. You should NEVER have current flowing on a ground wire.
Old 01-09-2012, 07:19 PM   #11
Thanks to everyone for all the suggestions. I am going to switch off the breaker and do some continuity tests to see if there is a short. I will let you know what I find.
Thanks!
Ron
Old 01-09-2012, 08:30 PM   #12
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Explain this a little better. What wires are in the switch boxes and how are they connected? Better yet, snap a pic.
I have a suspicion that there is a switch loop somewhere and the timer needed a neutral so the genius installer used the ground for it. This would do exactly what you are describing.
Old 01-10-2012, 07:58 PM   #13
Rewards Points: 240
Sort of related: Some years ago, I was setting up some workstation computers in a NASA facility. I had a workstation with a 27" CRT monitor positioned next to a pillar in the room, and depending on how I turned the CRT, I got big-time distortion from the pillar. The facilities engineer came by to see how we were doing, and I pointed at the monitor and said "There must be a lot of current running through the wiring in that pillar." He looked at me funny and said, "There's no wiring in that pillar!" Turned out that in another part of the facility, there were a bunch of old light fixtures where the original electrician had not bothered to run a neutral; he had just connected the fixture neutral to the box ground. There were all kinds of currents running around through the structural steel.
fa_f3_20 is offline   Reply With Quote
The Following 2 Users Say Thank You to fa_f3_20 For This Useful Post:
frenchelectrican (01-10-2012), Speedy Petey (01-10-2012)
Tags
ground spark wiring lamp
Removing old light fixture & install ceiling fan sjk Electrical 3 04-17-2011 08:32 AM
Three light fixture only one light works jenwoode Electrical 1 09-21-2010 12:08 PM
New Member, New House Owner, New Light fixture kingston73 Electrical 3 09-19-2010 06:13 PM
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 08:15 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
