Spare Cable Inside Conduit...allowed? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2011, 10:10 AM   #1
Rewards Points: 24
Question
Spare cable inside conduit...allowed?
Hello
Due to a modification in my home, I had to do some rewiring inside my house, (1/2 in emt conduit,inside concrete running #12 thhn cable ) I had to divide a circuit (kitchen, receptacles) and I added a 20 amps breaker. The matter is that on 4 outlets I added a green cable for ground, that probably was not needed because the emt conduit, but since I had such a hard time passing the wires trough the conduit I wired an additional white wire which is properly labeled as spare. In other words, on a section of the conduit I ran 6 #12 thhn wires and 4 of them go to 2 separate 20 amps breakers, one is ground and the after mentioned spare. This additional cable has wire nuts, and is well protected with black tape. Can I leave this connection as it is, or am I doing something wrong or code prohibited?
newguynet is offline   Reply With Quote
Old 02-18-2011, 10:15 AM   #2
Scared Electrician
Saturday Cowboy's Avatar
yes you can leave unused wires in a conduit
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
The Following User Says Thank You to Saturday Cowboy For This Useful Post:
newguynet (02-18-2011)
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 01:50 PM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 09:39 AM
Allowed to run more than one romex cable through a single hole in a joist? J187 Electrical 7 08-17-2007 09:46 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
Pigtail inside panel box. Code allowed? KUIPORNG Electrical 7 08-22-2006 04:45 PM
