#1 |
Spaghetti Mess
I have a fews questions regarding the way my electric was done in my house. A quick background... Only been here about 3 yrs, the house was built in 1940 and is 1400 sq\ft. Most of it has been updated as you can see by the links below, but it is an absolute mess. It is a 100 amp service and the 20 breaker Siemens panel is almost full. There are two breakers in there not being used. As far as electric goes, I only feel comfortable running wire, hooking up plugs and lights. My ?'s are:
I have read I can go to a larger GE panel (30 breakers) on my current 100 amp service. Is this correct? I have also read another option would be adding a sub panel. Considering the mess I currently have, which would be the better option and how is the sub panel added? Does anyone have a good electricity calculator to find out if I should have my service upgraded? In the first picture you can see where my main line comes in to a large circuit box and then they have two smaller boxes branching off of that as well as a line over to the main panel. This just doesn't look right to me. Is this OK to do? Also, I still have a few lines that are aluminum. How critical is it that these be updated. I am planning on hiring a professional to do any service or panel upgrades I might need. I am just looking for the right info to get me headed in the right direction. I don't want someone selling me something I don't need and I want this done the right way. Any help you could give would be greatly appreciated. Main plus more mess http://www.scottmuth.com/main.jpg Mess of a panel http://www.scottmuth.com/panel.jpg Thanks, Scott... |
#2 |
Spaghetti Mess
You've got a bit of a mess.
Your equipment (panel) inside looks OK but the wiring is very sloppy. I'm sure that the disconnects have issues but I cant see thru the covers ![]() Call 2 or 3 local contractors and have them look deeper into the system. |
#3 |
Spaghetti Mess
Thank you, but I was hoping to maybe gather a little more info than that. Can you answer any of my questions for me?
#4 | |||||
Floor Sweeper
Spaghetti MessQuote:
http://www.selfhelpandmore.com/home-...ation-2002.php Quote:
Any larger aluminum cables such as for ranges, etc. is fine if it is terminated properly. Quote:
#5 | ||||||
Ok but you are really better off having someone look closely at your system. I'll give you five minutes ( which is $7.08 )Quote:
#6 |
Electrician
Spaghetti Mess
I liike on the tub where it says front, if it didn't say that someone for sure would have installed it with the breakers faceing the wall.
#7 |
Spaghetti Mess
Thanks for everyone's input. The inside of the disconnect just has one pull out breaker and some rust. I am having someone come out to look at it tonight. I am going to upgrade the service to at least 150amp and have the panel replaced. The sub panels off of the main and the way the wiring was done freaks me out. This way I can have all of my issues taken care of with an upgrade of service. I only have three runs that are still aluminum and I feel confident replacing that wire once the new panel is finished.
I was told I can alleviate the main disconnect if the panel is closer to the meter. Is this correct? If so, I would probably just move the panel to where the main is at. In doing so I will have to junction a lot of the wire to move it over there. Is this ok? Thanks again! |
#8 |
Chicago, IL
Spaghetti Mess
Looks like the bonding jumper is in place (incorrect) at that load-side panel in the second picture.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#9 |
Spaghetti Mess
Man, I wish I knew what that meant.
Hopefully the electrician can let me know tonight. Thank you for the heads up
#10 |
Floor Sweeper
Spaghetti Mess
Yes. If any circuits are ran nearby where the main disconnect is they could be rerouted to the main panel in the new location. If it is all carefully planned out you probably won't need to splice on to very many circuits.
#11 |
Spaghetti Mess
The electrician said he wanted $1200 to run a new line from the poll and the new 150amp panel. He said the code for the disconnect has changed and as long as "it is a reasonable distance from the meter", I do not need the disconnect. $1200 seems like a lot. Is this about right? the panel will be about 10-12' from the meter outside
#12 |
DIY Homeowner
Spaghetti Mess
...because there are some many variables that can affect them. Consider calling someone else for an estimate, that will give you a better idea. Also check references, BBB records, etc and ask if the appropriate permits will be pulled. Consider speaking to your local government and/or utility to see what permits are required. This is serious work. I would be more concerned about shoddy workmanship than the cost.
(FWIW, your estimate does not strike me as unreasonable, but again there are so many unknown (to me) variables involved a huge range of numbers would be reasonable.) One comment -- I'd recommend 200A... unless your house is small or your service load very low. Cost should not be much different. RST |
| Display Modes | |
| Another 3 way Mess | JPM | Electrical | 5 | 02-11-2009 03:47 PM |
| leaky vegie sprayer has created mess below!! help please | rulerofchaos | Plumbing | 1 | 10-01-2008 07:04 PM |
| Help with a mess | James Con | Electrical | 14 | 06-19-2008 12:17 AM |
| Countertop (Formica) mess and husband's ego - HELP! | frustratedwife | Carpentry | 3 | 11-12-2007 11:10 PM |
| Decorating my living room - a mess! | mikailani | Interior Decorating | 4 | 10-21-2007 05:57 PM |
