Spacing Requirements For Circuit Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2012, 12:40 PM   #1
Spacing Requirements for Circuit Breakers
What does it mean when they mention "Thru Air and Over Surface" for minimum spacing requirements for circuit breakers?
inmars is offline   Reply With Quote
Old 02-20-2012, 05:48 PM   #2
Master Electrician
Rewards Points: 3,746
Where and who mentions this?
brric is online now   Reply With Quote
Old 02-20-2012, 06:32 PM   #3
Through air: between two conductive parts in the air of the shortest distance.
Over surface: between two conductive parts measured along the surface of insulating material the shortest distance
hawkeye11 is offline   Reply With Quote
Old 02-20-2012, 06:43 PM   #4
Basically, this is the responsibility of the manufacturer of products, such as service panels or any other equipment. Basically, this refers to the minimum spacing between uninsulated live parts of opposite polarity; and between an uninsulated live part and a grounded part and mounting surface.
Old 02-20-2012, 07:46 PM   #5
BRRIC, the nccer level 2 electrical text book in chapter 10 talks about established voltage ratings are based on clearances or space both through air and over surfaces between components of the electrical system, and I am having a hard time wrapping my mind around what they are talking about.
Hawkeye11, Thank you for the synopsis.
breakers compatible with panel--HD says... Daneel Electrical 6 06-10-2011 07:31 PM
Different styles of pushmatic breakers (bolt spacing/ location) codeman112 Electrical 24 11-24-2010 11:36 AM
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 08:07 AM
Can I install tandem breakers to stop my breakers from tripping? sofakng Electrical 1 04-29-2009 02:44 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 01:58 PM
