Spacing Criteria - Electrical - DIY Chatroom Home Improvement Forum
Old 05-12-2009, 12:03 AM   #1
Rewards Points: 81
Spacing criteria
Hello. I need some suggestions with the following setup. I have a sliding glass door which used to have a combination curtain/flourescent light setup. I took it down and plan to install vertical blinds. I don't like flourescent bulbs and have been trying to find something else to replace them with. From the top of my sliding glass to the ceiling is about 15.5 inches. The Headrail for the vertical blind is 3.75 inches so that would leave me with about 11.75 inches space from the top of the headrail to the ceiling. About 5 inches down from the ceiling on the wall I have an outlet plate which was installed horizontally (and which the flourescent unit was plugged into). That means I would have 4 inches from the bottom of this outlet plate to the top of the headrail. What kind of lighting, trak lighting, LED, etc. could I install into this small space between the ceiling and top of the headrail without having to worry about it burning my blinds? I don't need a lot of light but I'd like to have some lighting. I went to HD and Lowe's and wasn't impressed by what they had and the halogen trak lighting they did have was very hot. Thanks
joefromcal is offline   Reply With Quote
Old 05-12-2009, 07:40 AM   #2
What are you trying to light? Do want direct light in the area in front of the door, or just reflective light to lighten the room? There really isn't enough room to put anything but a flourescent there without worrying about the heat. One suggestion is to build a valence under the flourescent fixture so you can't see the fixture from the ground, and the light only shines up and washes the ceiling. they have flourescent bulds now that are not as harsh in color temp and look more like real daylight.
Option B for downlighting would be some sort of track fixture with small halogen heads mounted on the ceiling and pointing down in front of the door. OR mount them on the wall above where the outlet is.
Burbman is offline   Reply With Quote
Old 05-12-2009, 12:20 PM   #3
Rope light.
220/221 is offline   Reply With Quote
Old 05-12-2009, 12:39 PM   #4
Rewards Points: 506
Send a message via AIM to theatretch85
I'd say either the LED puck lights (or LED strips) or the Xenon puck lights. The xenons are said to not get nearly as hot as the halogens do, I haven't tried them yet, but I will be installing some under my cabinets in the kitchen soon (the xenon pucks).
theatretch85 is offline   Reply With Quote
Tags
led , spacing criteria , trak lighting
fastener spacing DangerMouse Building & Construction 3 04-22-2009 08:30 PM
Stud spacing... dstylez Building & Construction 4 03-12-2009 02:09 PM
Grout Color Choice / Spacing jamiedolan Tiling, ceramics, marble 11 12-25-2008 02:00 AM
Pier Spacing my5sons Building & Construction 3 11-03-2008 02:05 PM
Conduit Spacing / Separation smitty286 Electrical 3 04-08-2008 10:11 AM
