Old 12-05-2012, 07:41 PM   #1
spacers
Receptacles go too far into box. Can steel washers be used to shim out a 1/8 -1/4"? Thanks.
gt1935 is offline   Reply With Quote
Old 12-05-2012, 07:46 PM   #2
Lic Electrical Inspector
electures's Avatar
spacers
Is the box flush with the finished surface?
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 12-05-2012, 07:48 PM   #3
electures's Avatar
spacers
Use an add-a-depth ring and nuts or washers behind it to secure it. Sometimes the ring is enough.
Sizing motors
Old 12-05-2012, 07:57 PM   #4
spacers
No. 1/8" -1/4". The box is for 3 receptacles. If the extender box goes past drywall? Existing metal box does the extender need to be metal or can it be plastic? Thanks.
Old 12-05-2012, 08:07 PM   #5
electures's Avatar
spacers
They are available in both metal or plastic.
Sizing motors
Old 12-05-2012, 08:51 PM   #6
Licensed electrician
spacers
Arlington makes plastic ones. Look for BE1, BE2 and BE1R for round boxes. They can be ganged for larger boxes.
small spacers for woodgrain ceramic tiles? maybe none? vote4Pedro Flooring 17 12-22-2011 11:46 PM
Spacers, the final frontier? Is one better than the other. wraiththe Tiling, ceramics, marble 1 12-13-2011 05:37 PM
Question About Glass Block Spacers MisterPG General Discussion 5 04-21-2010 04:44 PM
Ceramic Floor Tile Spacers Arlo Flooring 9 06-18-2008 06:27 PM
Floor spacers when installing laminate floor flybynite Flooring 4 12-04-2006 10:24 PM
