Spa Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 09:55 PM   #1
Spa sub panel
Do i need to use a sub panel specifically labeled as a "spa sub panel"
Can i use a 4 or 6 space weatherproof main lug say murry or square d and just add in my own gfci breakers?
And do the gfci breakers need to be in the sub panel or can i put them in the main service and use standerd breakers in the sub panel?
Kenny101 is offline   Reply With Quote
Old 02-15-2012, 11:52 PM   #2
Dose this not make sense or what? Is it recommended to use a pre manufactured spa subpanel?
The Following User Says Thank You to Kenny101 For This Useful Post:
J. V. (02-16-2012)
Old 02-16-2012, 12:13 AM   #3
Julius793's Avatar
I think your fine either way but I'll check the code to make sure. Code requires a gfi outlet near the spa are you aware?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-16-2012, 12:17 AM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Kenny
It doesn't make any difference where you install the gfci protection. It is more common to use a spa panel as the required disconnect. That disconnect needs to be within sight but not closer than 5 feet from the spa. These panels often allow for a 40 or 50 amp double pole gfci and the addition for a single pole breaker to run your branch circuit to the required servicing receptacle.
Also the feeder wires from the panel that is bringing power to the spa panel needs to be in an approved conduit. The wires all must be insulated and the correct colors.
Installation of a spa requires strict compliance with code for a safe installation. I suggest you download a free copy of the NEC article 680 and use the search engine on this site to research your project.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-16-2012, 09:33 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 246
A spa panel will be cheaper than buying a single panel, then a 50 amp gfci breaker.
jbfan is online now   Reply With Quote
Old 02-16-2012, 10:00 AM   #6
liscenced electrician
Rewards Points: 538
There's a few options. A disconnect is required by the hot tub but it doesn't have to be fused. If you can get a gfci breaker for your main panel then go that route and put a cheap $15 non fused disconnect by the hot tub. If you can't get a gfci breaker for a reasonable price, then get a disconnect made for hot tubs with a gfci breaker pre installed
jimmy21 is offline   Reply With Quote
Old 02-16-2012, 12:23 PM   #7
Rewards Points: 82
Use a spa disconnect panel like this. It has the 120 volt convenience receptacle included. Easiest way to go.
Panel cleanup gdoucette Electrical 5 06-26-2010 03:01 PM
Sub Panel SoxFan Electrical 2 12-02-2008 11:16 AM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 03:15 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
