Sorry, But Another 3 Way Switch Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-17-2009, 07:24 PM   #16
joed's Avatar
Rewards Points: 13,354
This would be the drawing to go along with the above description.
Old 03-18-2009, 04:13 AM   #17
Vann
Originally Posted by dSilanskas View Post
DONT RUN ANOTHER WIRE ITS NOT NEEDED!
Its simple do it this way you will need a four way switch.
Step 1 - The 3 way switch in the first box your going to remove
Step 2 - The black from the feed splice with the black from the new 14/3
Step 3 - This is where you need the 4 way. Your going to install it in the first box where I had you remove the 3 way. The red and white from the new 14/3 will now become travalers. Attach them to one side of the 4 way. The travelers that where attached to the 3 way you removed put them on the other side of the four way.
Step 4 - The new 3 way will have black as your common and red and white as your tavalers.
You will notice on the 4 way that the travalers might be different colors dont worry about that it doesn't matter. Just follow the steps and if you need anymore help just ask :-)
Sorry sorry he's 100% correct, i realiezed afterwards you can do it just like he says.
vann is offline   Reply With Quote
Old 03-18-2009, 07:42 AM   #18
Although it took two attempts, your solution worked like a charm. I must have originally reversed the "sides" of the 4 way swith for some of the travelers, as it turned power to the other switches off completely. After switching the travelers around, it works perfectly. I assume that if it works, it is hooked up correctly?
Thanks - my wife thinks I am a genious.
SR996 is offline   Reply With Quote
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
GFCI switch to control outside outlets billgeo Electrical 14 09-08-2008 11:09 PM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 05:53 PM
Beginner Question - Residental Switch willedon Electrical 6 03-31-2008 08:12 PM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 07:47 PM
