Old 11-21-2007, 08:09 PM   #1
Something Weird Happened
As were doing some work in the kitchen, we turned off the circuit breaker. None of the work were doing was electrical - it was just a precaution. When we turned it back on, only one outlet was working! The other three were not. There are 3 appliances on this curcuit (fridge, microwave & garbage disposal).
The fridge works A-OK, but suddenly now the microwave & disposal aren't getting any power. They worked fine when I connected an extension cord to another source. And there IS juice getting to the outlets but the outlets themsleves are no longer converting.
Is there any cause or remedy for this? Should I just replace the outlets? Is it something in the box?
ANY help or advice would be great. Thanks!
dbrit423 is offline   Reply With Quote
Old 11-21-2007, 08:22 PM   #2
Electrician Apprentice
puma1277's Avatar
is there a GFI?
puma1277 is offline   Reply With Quote
Old 11-21-2007, 08:40 PM   #3
GFI maybe behind the fridge? Were you doing any demo work on that wall?
RichyL is offline   Reply With Quote
Old 11-21-2007, 08:59 PM   #4
Electrician philosopher
How old is the house. Possibly loose connection. POWER OFF and start the hunt if it ain't a GFCI.
The hunt is my favourite.
Andy
Andy in ATL is offline   Reply With Quote
Old 11-21-2007, 10:17 PM   #5
What does this mean? Have you tested the outlets, and found that they have 120V, but the appliances don't work when plugged in?
If that's the case, I think you might have an open neutral between the fridge receptacle, and the next receptacle downstream.
NateHanson is offline   Reply With Quote
Old 11-21-2007, 10:44 PM   #6
Union Electrician
goose134's Avatar
I agree that you should check for a GFI behind the fridge. However, microwaves on the load side of a GFI sometimes nuisance trip. This is a more likely scenario:
If you do have an open neutral, please find out if it is connected to a multiwire branch circuit. (two hots sharing a neutral). If it is, kill BOTH circuits before splicing it again. Getting hit on an open neutral is no fun. Especially under load. Good hunting!
goose134 is offline   Reply With Quote
Old 11-21-2007, 11:42 PM   #7
Flip the breaker a few times. Sometimes they don't like to come back on.
220/221 is offline   Reply With Quote
Old 11-22-2007, 05:20 AM   #8
Huh??
Old 11-22-2007, 07:52 AM   #9
It is VERY odd for a fridge, being on a small appliance countertop outlet branch circuit, to be on the same circuit as a disposal, which should NOT be on the small appliance branch circuit, to be sharing the same breaker. Is this a 1 pole or 2 pole breaker? Further, if the microwave is a plug-in, countertop model, it can go anywhere, but if it's a built-in, over-the-stove combination microwave / vent hood built into the cabinets, that too should not be on the SABC either. Maybe you have a 2-pole breaker and one side isn't resetting?
LawnGuyLandSparky is offline   Reply With Quote
Old 11-22-2007, 08:03 AM   #10
Thus my question...How old is the house. My parents house (1980) is one big happy circuit going around the kitchen and catching the garage for good measure.
Old 11-22-2007, 01:24 PM   #11
Huh??
You've never seen a breaker that didn't want to reset?
I have....many times.
I have had them NEVER come back on, or only one pole of a two pole comes on.
Old 11-22-2007, 01:33 PM   #12
Gosh 220, I'd replace the breaker at that point. If it is resetting into a fault, I believe "technically" it has to be replaced after two resets. If it is just being stubborn on a clear circuit, I tend to lose faith and replace the breaker...Don't want to put peoples lives at risk with a sticky breaker that once I have forced it closed may not open under fault conditions.
Off to eat turkey.
Old 11-22-2007, 08:02 PM   #13
Union Electrician
goose134's Avatar
I wasn't suggesting that they were. I was thinking that they may be part of a MWBC. If you lost the noodle on one, you'd "lose power" on both. Just a thought. Happy turkey day everyone!
Would this look weird? joeyboy Interior Decorating 27 12-16-2007 09:53 AM
200 amp service, someone explain what may have happened? Piedmont Electrical 16 12-12-2007 09:31 PM
Weird HVAC configuration need your thoughts Rikky HVAC 2 09-10-2007 04:11 PM
Weird layout - need advice please!!! handygal Plumbing 3 08-27-2007 09:54 AM
What happened here? Dusty Painting 9 09-17-2006 09:43 PM
