Someone Put A Screw In The Ground On My Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2011, 10:05 AM   #1
master of none
Wookie's Avatar
Rewards Points: 14
Question
Someone put a screw in the ground on my outlet
Hi everybody. I'm buying my first house and I have a question for all of you sparkies.
On one wall in my kitchen, somebody has gone and stuck a small screw in the "ground" hole in every electrical outlet, and then painted over them.
It's not an old house, its only about 10 years old.
Not sure why anybody would ever do that.
Any takers?
Wookie is offline   Reply With Quote
Old 07-09-2011, 10:23 AM   #2
Electrical Contractor
kbsparky's Avatar
Probably because there is not a good ground connection present ... I'd check for the presence of an equipment grounding conductor before proceeding further.
-KB
Old 07-09-2011, 11:56 AM   #3
Rewards Points: 1,016
Yup, sounds like there is not ground - and the screws were someone's way of thinking they were dealing with it...
____________
Vince
Old 07-09-2011, 12:02 PM   #4
Rewards Points: 58
Ground hole? The threaded hole inside on the back of the box? That's where the grounding jumper goes if you have a metal box. If the boxes are plastic, the grounds get connected together and one lands on the receptacle ground terminal. I am not certain I understood your question.
Old 07-09-2011, 12:43 PM   #5
Licensed electrician
Rewards Points: 1,038
Sounds like someone did this to make a three hole receptacle a two hole receptacle.
Old 07-09-2011, 02:12 PM   #6
master of none
Wookie's Avatar
Rewards Points: 14
Sorry. I am referring to the third, lowest hole on the face of the receptacle - the "ground hole".
Open Ground in Non Daisy Chained Outlet Circuit RileyRR Electrical 2 05-18-2011 03:00 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
connecting ground wire to green gound screw sco Electrical 0 09-22-2010 06:43 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Changing an outlet, Grounding Procedure jamiedolan Electrical 15 10-12-2008 11:07 AM
