Someone Cut All The Wires - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-02-2009, 09:16 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Oh, OK. Sorry I missed that line.
Yeah, no reason at all to do this. Boxes are legal as long as they remain accessible, among other code requirements.
Old 08-02-2009, 09:52 PM   #17
Issue of replacing FPE panel!
Originally Posted by Gigs View Post
It sounds like they might have done it as a service to force the next owner to fix a dangerous electrical situation. Crude but effective. Make sure to get someone to check all the wiring in the house. As others have said the FPE is junk and you should get rid of it.
Your best bet (in a complicated situation, with the wiring) is to get several estimates from Licensed Electrical Contractors. I'm sure, after fixing all the electrical and plumbing problems (due to sabotage), you could still feel you made a good deal on the house. Good Luck. (No matter what) Don't drink and Drive!!!
spark plug is offline   Reply With Quote
Old 08-04-2009, 11:13 AM   #18
Originally Posted by Speedy Petey View Post
Sure, get three electricians in there for estimates. Pick the one you are most comfortable with.
I'm liking this answer. Don't do it yourself, doing a panel can easily be done wrong if you don't know what you're doing. It's not as simple as plugging wires into breakers.
Super33 is offline   Reply With Quote
Old 08-05-2009, 09:13 PM   #19
jbfan's Avatar
Rewards Points: 648
Originally Posted by vsheetz View Post
I would like to hear more of the trough and nipples solution too, something I have not hear of. Please elaborate?
We took a couple of 1 1/2 inch nipples and ran into a trough.
The trough was made to fit inside the studs, ran thhn throught the nipples, made taps in the troughs. This only worked on the cable that was cut flush with the panel.
In the OP case, all the wires seem to be cut in the attic, so this would not work.
jbfan is online now   Reply With Quote
Old 08-06-2009, 06:14 AM   #20
Whatamess
Is it possible to move the box up so you can splice the wires in the new box or will it be to high for code?
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-06-2009, 07:27 AM   #21
RustyRealtor's Avatar
Rewards Points: 287
I think it'll be too high. They cut the the wires about a foot above the box. I think I will us junction boxes. It shouldn't be too difficult, except for the heat up there. August in FL.
Thanks,
Russell
RustyRealtor is offline   Reply With Quote
Old 08-06-2009, 08:18 AM   #22
the Musigician
DangerMouse's Avatar
Come on. Like they'd care.
This is a vindictive act of revenge due to losing their home, plain and simple.
gotta agree with you there Pete!
DM
Old 08-06-2009, 09:12 AM   #23
Chicago, IL
Michael Thomas's Avatar
\If this is an older house, you may also want to consider upgrading the service when you replace the panel.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 08-06-2009, 09:25 AM   #24
Rewards Points: 287
The house was built in 1980. I think it has a 200 amp service. Federal Pacific, of course. Those FP panels are everywhere down here.
Thanks,
Russell
Old 08-06-2009, 08:22 PM   #25
Ubiquity (almost rhymes with Obituary) of FPE
Not only down there in Florida but also up here in the Northeast, in the Midwest, Southwest and Northwest. They were the most (At one point even more so than Square D) popular brand. That's why it hurts so much to have found out that they were a piece of junk. No. A fire hazard!
(Now more than ever)Don't Drink and Drive!!!
Last edited by spark plug; 08-06-2009 at 08:24 PM. Reason: Typographical error (Typo)
Old 08-06-2009, 09:14 PM   #26
Well, being an electrician, it doesn't hurt my pocket book much.
Old 08-06-2009, 09:46 PM   #27
Not crying over demise of FPE
Good point. I wish (primarily for safety's sake) the City (AHJ) would back away from the "Grandfathering" rule and order all the existing FPE products replaced. On that basis alone, the recession will end (At least for the electricians) without any stimulus funds! (Now more than ever) Don't Drink and Drive!!!
Old 08-06-2009, 10:51 PM   #28
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
My 2 cents.
I'd consider seeing how hard it would be to replace the home runs or ask an electrician to just replace them I hate junction boxes in this type of situation but as Speedy has said it is perfectly legal and would be your easiest solution.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-07-2009, 08:01 AM   #29
Rewards Points: 287
I too would rather replace the home runs. But it probably quadruple the cost. The attic is very tight and the electrician would have to do a lot of belly crawling.
Thanks,
Russell
Old 08-07-2009, 08:46 AM   #30
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
How did the original electricians get away with installing a panel in a limited access attic space? If you were to replace the panel, the inspectors probably wouldn't let you reinstall in the same location.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
