Someone Cut All The Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2009, 06:54 PM   #1
RustyRealtor's Avatar
Rewards Points: 283
Hello Again,
I am trying to buy a bank owned house down in FL. Before the person who lost the house left the house they cut every electrical wire coming out of the breaker box. The breaker box is a Federal Pacific brand and needs to be replaced. It seems that a large junction box would be in order up in the attic, but the wires come from several directions and I am not sure everything would reach the junction box or even if a large junction box would meet code. Any ideas or suggestions?
Many Thanks,
Russell
RustyRealtor is offline   Reply With Quote
Old 08-02-2009, 06:58 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Sure, get three electricians in there for estimates. Pick the one you are most comfortable with.
Old 08-02-2009, 07:01 PM   #3
Household Handyman
Rewards Points: 1,408
Hmmm, did they cut the wires inside the breaker panel or outside the breaker panel? It sounds like outside of. Being as it is a FPE panel I would start with getting rid of it, and replacing it with a better brand. Now, if the wires will reach inside of the new panel, you can splice the wires inside of the new panel using wire nuts or another appropriate connector. IF the wires will not reach inside of the new panel, I would eiher 1) hire a competent, licensed electrician for help on this who would know about using a box in the attic to terminate the wiring, or 2) contact the local code office and just plain ask them about the legal/code aspect of terminating the wires within a junction box in the attic. Multiple junction boxes may be in order vs. rewiring the house, provided the are within code compliance. Good Luck, David
Old 08-02-2009, 07:02 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
I did one like that in the past. Put a trough in the top and the bottom, then ran nipples to the panel.
Sure made it hard on the sheetrock guy.
jbfan is online now   Reply With Quote
Old 08-02-2009, 07:09 PM   #5
Rewards Points: 283
Thanks for the replies. I will contact the city.
I don't understand the troughs and nipples, jbfan.
Thanks,
Russell
Old 08-02-2009, 07:13 PM   #6
Rewards Points: 283
And yes they cut the wires outside the box. They knocked a hole in the ceiling and cut everything about a foot above the box.
Old 08-02-2009, 07:15 PM   #7
Why would you contact the city?
Old 08-02-2009, 07:28 PM   #8
DIYer
It sounds like they might have done it as a service to force the next owner to fix a dangerous electrical situation. Crude but effective. Make sure to get someone to check all the wiring in the house. As others have said the FPE is junk and you should get rid of it.
Gigs is offline   Reply With Quote
Old 08-02-2009, 07:32 PM   #9
Come on. Like they'd care.
This is a vindictive act of revenge due to losing their home, plain and simple.
Old 08-02-2009, 07:46 PM   #10
Rewards Points: 1,016
Agreed - sadly, I have seen people huge amounts of damage on the way out...
Old 08-02-2009, 07:48 PM   #11
I would like to hear more of the trough and nipples solution too, something I have not hear of. Please elaborate?
Old 08-02-2009, 07:55 PM   #12
kbsparky's Avatar
Did they remove (STEAL) some of the wiring? Or are they all just cut?
When scrap wire prices were higher, many houses -- especially empty ones in foreclosure -- had some of the wiring cut and removed by copper theives.
-KB
Old 08-02-2009, 08:39 PM   #13
Rewards Points: 283
I said city, but I meant code enforcement. They didn't steal any wire, just cut everything. They also knocked holes in all of the walls, painted the tile with spray paint and destroyed the rear screened porch. It's all fixable. The wiring has me a bit baffled. I do my own electrical and try to do it all to code. You good people helped me install a new circuit box in my last house. This dilemma is something I've never had to deal with. I think I can still back out of the deal and try to find a place with wiring intact. I do love a challenge, though.
Old 08-02-2009, 08:47 PM   #14
Again, what do they have to do with it?
Old 08-02-2009, 08:58 PM   #15
Rewards Points: 283
2) contact the local code office and just plain ask them about the legal/code aspect of terminating the wires within a junction box in the attic. Multiple junction boxes may be in order vs. rewiring the house, provided the are within code compliance. Good Luck, David[/quote]
It was suggested by Thurman that I contact code compliance.
Personally, I like to keep the city out of things like this.
Russell
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
