Some US - UK Translations Required - Electrical - DIY Chatroom Home Improvement Forum
Old 07-29-2008, 03:04 PM   #1
Question
some US - UK translations required
Hi All
I am hoping someone can help, firstly i have very little electrical knowledge so please bare with me.
my boss (US based) has asked me to investigate if this item will work in my UK office - http://www.ceia-melters.com/detail.asp?a=002
the building i have has 3 phase power and indicates 500v with 60amps.
I can see from the requirements that it requires 220v or 400v to operate (i have 500v so i asume thats fine) but i dont understand what 'Hz' is? is this the same as we refer to as Amps in the UK?
Your input apreciated, i will be contacting my electrician in the morning to confirm but thought you guys might be able to give some idea.
BB
BikerBudgie is offline   Reply With Quote
Old 07-29-2008, 06:28 PM   #2
The "units" of speed could be miles/hour or feet/second or furlongs per fortnight. The "units" of Hz is "per second ["/sec"]."
60 Hz is some thing that happens 60 times per second. In this case what is happening 60 times per second is that the voltage goes from zero to a positive value and then back to zero and then to a negative value and then back to zero.
And at 60 Hz the cycle is completed in 1/60 = 16.7 milliseconds = 0.0167 seconds.
Old 07-30-2008, 02:31 PM   #3
Rewards Points: 78
The crucible will work on 50 or 60 Hz. Find out what the nominal voltage is for your area. I think you will be just fine. I would verify with the manufacturer and your power company before you write that PO.
Compressor cfm rating required for framing nailer tmeehan Tools 8 05-01-2009 12:17 PM
is a pre-slope required for slab shower memjeff Plumbing 2 01-16-2009 07:57 PM
What is required to eliminate electric from office wall? flatlander745 Electrical 5 05-31-2008 11:41 PM
How to determine DC amperage required for small device? quexal Electrical 3 05-11-2008 02:04 PM
Stapling required for fished new wires? cheapohubby Electrical 1 04-13-2008 10:54 PM
