Old 06-06-2009, 04:26 PM   #1
some outlets not working
Yesterday I had 4 of my power outlets to quit working. One in the living room ,one in the dinning ,one the back bedroom and one in front bedroom. I did some poking around in the panel box on the inside and found the circuit they where on, the crazy thing is some stuff on the same circuit or breaker still works. I checked all the white wires and they where tight. I even killed the power to box on the inside and put them on new lugs nothing? My VM says there is power on the circuit but when I check the outlets themselves I get only a little bit of power on them. So does anyone have any suggestions on what this could be.
Clallen is offline   Reply With Quote
Old 06-06-2009, 04:42 PM   #2
The outlet wires are run from one outlet to the other. The frst outlet has a broken or disconnected wire. Probably broken on the outlet screw.
Open them up and check them out.
Ron
Old 06-06-2009, 04:44 PM   #3
It was a dark and stormy
Yoyizit's Avatar
It'd be good if you could figure out which outlets are downstream of which on this particular circuit, and then start at the most upstream outlet, the one closest to the CB panel, that works.
Old 06-06-2009, 07:33 PM   #4
Xtreme DIY'r
Any GCFI outlets anywhere?
Old 06-08-2009, 02:31 PM   #5
I have looked inside a few so far nothing, but I took the Vw a while ago on LB and stuck it in some of the other oulets and on one of them I found only 20 volts so I may have found it, I just got to get some time to go inside and fix it thanks for all the help everyone ....
Old 06-08-2009, 05:09 PM   #6
Yoyizit's Avatar
Sounds like a
http://en.wikipedia.org/wiki/Phantom_voltage
so it probably is not a GFCI because you are still getting 120v into at least one conductor. GFs interrupt both the hot and the neutral.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Outlets stopped working RammsteinNicCage Electrical 12 05-03-2009 10:47 PM
side by side light swithes not working katkell2645 Electrical 2 10-17-2008 08:22 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
Electrical storm - outlets not working SG94 Electrical 4 04-27-2008 10:28 AM
