Some help with electrical math please- UPS
A 3w bulb is going to use a lot less engergy than the inverter circuit in the UPS.
If your looking for battery backed light, i would suggest an LED light running off a battery. You could use an AC powered relay that would enable a simple charger for the battery...when you loose AC, the relay de-energizes and turns on the LED. You will get a lot more run time that way.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
