Solved One Mystery, Created Another - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2010, 06:43 PM   #1
msk
solved one mystery, created another
as helpful as everyone was last night, i knew i'd be back, but i was hoping not so soon. after finally figuring out a 4 way controlling half of an outlet series, i realized that a different 3way setup was not working. I'd replaced these switches also in my quest to change the color on all my switches/plates/etc. so i switched them and everything worked fine.
after messing with the 4way, now they dont work, along with 2 bedrooms on the same breaker. the 4way is on a different breaker, but one of its 3ways shares a box with one of the 3 ways in question.
since the whole circuit is out i was hoping the breaker went bad, but no dice, i have power there but nothing at the switches.
any advice on what to check next? if i run a jumper between the three ways, i can check continuity both between the switches, and around the other side of the loop as well correct? if i dont have continuity, that would indicate a problem behind the wall somewhere?
i miswired twice on the 4way before getting it right, which caused 1 or 2 of the switches to work depending on the position of the others. did i do something that could have melted something in the wall? again, the 4way is on a different breaker, and still works.
is it possible that i still have the 4 way wrong and that is causing a problem?
no tripped gfci that i could find, a hallway and bedrooms shouldnt have one correct?
dont know if this is relevant, i did give myself a hell of a shock the other day, where the 2 circuits share a switch box, got fancy and decided i could work next to a live switch. point taken. when i tested for voltage at the switch i clamped to the screws, not the wire. is it possible the switch was destroyed inside? could this cause the whole circuit to be dead? should i check the wire itself (its one of the push in jobs)? I've messed with so many wires over the last week, im not 100% sure, but i swear it worked fine after that and i noticed it not working only after i got the 4way working.
thanks for any help, Mike
msk is offline   Reply With Quote
Wiring mystery cmaddy Electrical 6 07-12-2010 07:25 AM
Possible Breaker Problem mmcgrath Electrical 12 04-19-2009 09:41 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
large mystery plywood panel in garage - any thoughts on this?! joeyboy General DIY Discussions 15 12-02-2007 03:01 PM
Light Switch Mystery csteinke Electrical 10 06-06-2007 01:33 PM
