Solve This One - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2013, 07:41 PM   #1
Rewards Points: 506
Solve this one
3-way switch
Switch in position 1:
Black traveler terminal = 62v
Red traveler terminal = 120v
White common terminal = 120v
Switch in position 2:
Black = 0v
Red = 120v
White = 0v
All values referenced against the bonding conductor. Haven't opened up the other 3-way switch or the lights. Lights and switches appear to be functioning normally.
Where does the 62v come from?
jlmran is offline   Reply With Quote
Old 01-10-2013, 07:55 PM   #2
Rewards Points: 506
Deleted
Old 01-10-2013, 08:09 PM   #3
Missouri Bound's Avatar
Other than your voltages....what's the issue with the switches?
Do you want it your way or the right way?
Old 01-10-2013, 08:14 PM   #4
Rewards Points: 506
Unbonded while having metal covers. I learned of the voltages while verifying presence/absence of voltage. Unbonded status is now resolved. Why are you whistling?
Old 01-10-2013, 08:32 PM   #5
Rewards Points: 1,548
Red traveler is energized by the other switch.
Position 1 -- This switch connects white common to energized red. Your meter is sensitive enough to pick up phantom voltage induced in isolated black from red juxtaposed in same cable, voltage relative to bonding conductor.
Position 2 -- The switch connects white common to unenergized black traveler. Any phantom voltage is dissipated to neutral through load (light) at far end of white wire.
Wire color usage is incorrect. The white wire should not be used to go from the switch to the load. In this case you would need to use the white wire as a traveler.
Old 01-10-2013, 09:46 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,608
Originally Posted by jlmran View Post
3-way switch
Black = 0v
Red = 120v
White = 0v
Phantom voltage caused by close proximity to energised conductors !
Put a test lamp on it and I bet it goes away !
dmxtothemax is offline   Reply With Quote
Old 01-10-2013, 10:06 PM   #7
joed's Avatar
Rewards Points: 13,728
Agree with the above. No problem with the voltages. The switch is working properly. The 62 volts is phantom and not important.
Would upgrading to 200 amp service solve this problem? NancyNGA Electrical 7 03-01-2011 08:38 PM
Who can solve softener issues? turbomangt Plumbing 11 09-05-2010 02:10 AM
Wood Fungus, Will Timbor Solve this or ? twilightcall Building & Construction 4 06-05-2008 03:09 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
help me solve this mystery please lindaberrien Roofing/Siding 17 06-12-2007 01:06 AM
