Old 05-29-2009, 10:56 AM   #1
Default Solution for service on a lake dock
I need to run service for receptacle to my dock on the lake. the dck is taken odd the water for the winter, so I would like to be able to disconnect without messing with a junction box. I have a receptacle 6-8 feet from the dock with GFCI upstream. I was thinking about running a liquid tight conduit properly strapped with heavy nylon ties on the inside of one of the dock aluminum trusses and flex it up to one of the posts/legs and finish it wirh a water tight device box. On the land end I would like to run the flex loose on the ground under a 4' connecting ramp and plug it to a receptacle.
Does this seem like an acceptable solution?
Are there terminating plugs for flex conduit? If not can I terminate it on a "loose" box and run a pig tail out of it?
rdy2go is offline   Reply With Quote
Old 05-29-2009, 04:51 PM   #2
J. V.'s Avatar
No. Use straps listed for the conduit. Ty raps are not allowed. I would use PVC, not flex. You can use flex where the dock moves.
Come up under the dock roof. Attach the weather proof box to the truss there. (convenient).
Not on the ground. Attach it to the under side of the ramp.
This is really not a good DIY project unless you promise to get it permitted and inspected. Death or serious bodily injury may result.
The AHJ will have special requirements. He is who you should direct your questions too. No two inspectors will have the same opinion on this project. Or hire a licensed electrician to do it.
No. You will have to physically disconnect the flex and the wires when you are ready to move the dock. You also must have a disconnect where the new circuit starts. I would replace the existing receptacle and mount a small weather tight disco. You could use a 4x4 treated post and install the disco and receptacle on it. It would be easy to un-install the flex and wires from a disconnect. Since the circuit is protected by a GFCI breaker no other GFCI is required.
Check around and see what others on the lake have done in this regard. To give you an idea how others have done it. Ask if it was performed by a licensed electrician or contractor.
Old 05-29-2009, 05:43 PM   #3
I appreciate the comments. I will check what other guys around me have.
I have no problem with getting it inspected, but having to mess with wiring to move the dock is an operative issue. I had a new sub panel in the garage recently inspected. I will give a call to the inspector to see what his options are.
The other alternative I have considered is to install on land the battery charger, which would be the only regular use, and run the 14V/5 Amps line to the dock. Once in a while I will have to use an extension cord for vacuuming the pontoon or some power tool.
What kind of code issues/safety would I have with the 12 volts line?
Old 05-30-2009, 01:07 PM   #4
J. V.'s Avatar
You can use an extension cord as temporary power. Since you must move the dock, this may be the best way to go. Temporary. Thats the keyword.
More On This Topic
Learn how to adjust the truss rod to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
Hi, I'm John Sexton on behalf of Expert Village. Today we're going to be learning how to play Portal, a game by Valve Software. A company with which I have no affiliation. Here we are in the next test chamber, it is #07. We can see that the same... Read More »
Hi, I'm John Sexton on behalf of Expert Village. Today we're going to be learning how to play Portal, a game by Valve Software. A company with which I have no affiliation. Here we are in the next test chamber, number 13. We'll see how our luck is. We can... Read More »
Basic Hot Tub Wiring
Basic Hot Tub Wiring by Expert Village
OK, here we're going to talk about the different wiring requirements for spas. Many spas, most common will be a two-forty volt, fifty amp dedicated circuit, which means that is it on its own breaker, it is a GFCI breaker which is for your safety and also... Read More »
How to Dock a Boat
How to Dock a Boat by eHow.com
Learning to dock a boat is something that takes hands-on practice. These tips are just guidelines to help you start. As you practice bringing your boat to dock, you can hopefully perfect a style that works best for you. Read More »
proper wiring of outlets on dock near water elcid98 Electrical 5 05-04-2009 01:27 AM
Floating dock walk attachment pookemp Building & Construction 5 01-04-2009 08:48 PM
boat dock as house deck? raisingmn Building & Construction 0 08-05-2008 11:20 AM
sub pump in a lake rdmccaw Plumbing 2 05-02-2008 10:05 PM
Repainting A Steel Dock Duke76 Painting 4 02-24-2008 04:11 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
