Solid Vs Stranded Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 08-28-2014, 11:13 AM   #1
Rewards Points: 20
solid vs stranded wire
Thanks for a great place to learn and discuss topics of interest to us DIYers!
Mine is a general question regarding the use of stranded wire vs solid wire in EMT and PVC applications.
When and why would you use one over the other?
Is it a personal preference or restricted by code?
Can you mix the two on the same circuit?
Jim
tndiyguy is offline   Reply With Quote
Old 08-28-2014, 11:27 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 656
Jim
Personal preference, and they can be mixed in the conduit.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
Know A Little (08-29-2014), micromind (08-28-2014)
Old 08-28-2014, 11:33 AM   #3
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
for what I know, stranded wire should be 1 gauge larger than solid wire.
Gregg M.
gmaint is offline   Reply With Quote
Old 08-28-2014, 11:41 AM   #4
jbfan's Avatar
Rewards Points: 656
Not true at all!
The Following 9 Users Say Thank You to jbfan For This Useful Post:
clw1963 (08-28-2014), garlicbreath (08-29-2014), Know A Little (08-29-2014), micromind (08-28-2014), mpoulton (08-28-2014), PaliBob (08-30-2014), Speedy Petey (08-28-2014), stickboy1375 (08-29-2014), Stubbie (08-28-2014)
Old 08-28-2014, 11:51 AM   #5
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
Is stranded suggested for larger gauges?
clw1963 is offline   Reply With Quote
Old 08-28-2014, 12:01 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Mine is a general question regarding the use of stranded wire vs solid wire in EMT and PVC applications. When and why would you use one over the other?
There are situations where one or the other is a better choice. Solid wire is not easy to pull through conduit when there are bends in the conduit .. especially if it is a long run. Short straight runs it isn't much of a problem or runs that have a gradual bend to them for example when using flexible conduit.
Stranded wire is more flexible and much easier to pull through conduit with bends in the run and over distance. You also need to know how to terminate it depending on what the termination is .. ie .. box lug, non backwire style receptacle, fine stranded wire like in power cords have special connectors called ferrules in many applications.
Yes , In my case I almost always choose stranded in raceways/conduits. I only use solid when working with nm style cable or mc cable and the like.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following 3 Users Say Thank You to Stubbie For This Useful Post:
clw1963 (08-28-2014), ddawg16 (08-28-2014), micromind (08-28-2014)
Old 08-28-2014, 06:05 PM   #7
The bigger the diameter of the wire, the more stress you put on it when you bend it. I am no sparky, but I gotta figure somewhere in the code it says that if a wire is going to be frequently bent/moved (like an extension cord), the wire must be stranded.
SPS-1 is offline   Reply With Quote
Old 08-28-2014, 06:48 PM   #8
Idiot Emeritus
Rewards Points: 1,492
310.3 Where installed in raceways, conductors #8 and larger shall be stranded.
micromind is offline   Reply With Quote
The Following 3 Users Say Thank You to micromind For This Useful Post:
clw1963 (08-28-2014), Speedy Petey (08-28-2014), stickboy1375 (08-29-2014)
Old 08-28-2014, 06:49 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Where do people find these urban legend codes???
Old 08-28-2014, 06:50 PM   #10
Nope, this is not a code either.
You're talking about cable, not wire (conductors).
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 08-28-2014, 06:53 PM   #11
Idiot Emeritus
About the only advantage I can see to solid is it costs less (just the wire, not always the complete installation) and it makes up nice in panels, and it can be pushed into a longer run of conduit. Otherwise, my choice is stranded.
Old 08-28-2014, 08:51 PM   #12
Rewards Points: 455
me too. I think it's because it squashes out under screws and strands go all catiwhompus loosing amps everywhere
Cletis is offline   Reply With Quote
The Following User Says Thank You to Cletis For This Useful Post:
dmxtothemax (08-28-2014)
Old 08-28-2014, 11:06 PM   #13
Rewards Points: 4,796
Possibly because stranded wire is a larger diameter than solid wire of the same gauge? i.e. giving the impression that the stranded wire is a larger gauge, if you didn't know.
jeffnc is offline   Reply With Quote
Old 08-29-2014, 08:19 AM   #14
Rewards Points: 20
Originally Posted by Stubbie
Mine is a general question regarding the use of stranded wire vs solid wire in EMT and PVC applications. When and why would you use one over the other? There are situations where one or the other is a better choice. Solid wire is not easy to pull through conduit when there are bends in the conduit .. especially if it is a long run. Short straight runs it isn't much of a problem or runs that have a gradual bend to them for example when using flexible conduit. Stranded wire is more flexible and much easier to pull through conduit with bends in the run and over distance. You also need to know how to terminate it depending on what the termination is .. ie .. box lug, non backwire style receptacle, fine stranded wire like in power cords have special connectors called ferrules in many applications. Yes , In my case I almost always choose stranded in raceways/conduits. I only use solid when working with nm style cable or mc cable and the like.
Thanks for the great info!
The Following User Says Thank You to tndiyguy For This Useful Post:
Stubbie (08-29-2014)
Old 08-29-2014, 10:12 AM   #15
UAW SKILLED TRADES
Stubbie's Avatar
That's probably a good a reason as any though I've never understood how someone using electrical wire and reasonable common sense could misinterpret what to use when the wire is clearly labeled as to it's gauge ..ie.. 12awg stranded and 12awg solid both are the same for electrical installations. Speaking copper wire here. Anyone making that misinterpretation on electrical wire shouldn't be working on an electrical installation. I will say I've met many people who are capable of doing it.
Stubbie
Digitial Timer in 3 Gang box with (2) 3way switches and 1 single pole..confused. BCS Electrical 33 03-20-2016 11:30 PM
Stranded or solid wire Greenie Electrical 27 11-09-2012 05:39 PM
Best practices for splicing stranded to solid wire sixspeed Electrical 13 09-30-2012 01:46 AM
Stranded wire in breaker? gma2rjc Electrical 3 09-25-2010 12:00 PM
connecting straight wire to stranded Cossack Electrical 5 07-30-2010 01:52 PM
