Is Soldering Okay? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-01-2013, 10:22 PM   #1
Rewards Points: 948
Is soldering okay?
I was getting frustrated getting some stranded wire into a wire clamp. I put some solder on the wire, let it cool, and it slipped right in.
I know you can't make a connection that relies on solder, but that's not the case here. Is this okay?
Toller is offline   Reply With Quote
Old 05-01-2013, 10:27 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
tinning a wire should not be an issue...
Old 05-01-2013, 10:37 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,450
Actually, it's done all the time.
In some industries, it's a required way to do a crimp connection.
Don't confuse that with a soldered connection...different animal.
Old 05-02-2013, 07:16 AM   #4
Rewards Points: 1,492
A soldered connection is more reliable and longer lasting (except for physical damage) than any other kind of connection. Knob and tube wiring is regarded as hazardous partly because of concealed tee connections in walls and floors but if these are soldered (they usually are) they will never overheat from coming loose.
Soldered connections are more difficult to take apart if you want to change something. There is danger of melting the insulation, possibly causing a short circuit, when soldering. Some inspectors do not like soldered connections.
Old 05-02-2013, 07:31 AM   #5
joed's Avatar
Rewards Points: 12,362
AS long as you don't overheat it and damage the insulation tinning the tip of the wire is fine.
Old 05-03-2013, 10:24 AM   #6
Rewards Points: 126
Solder is rarely required with today's connecting hardware.
In fact, if you need to solder something that's not designed for solder, you are doing it wrong.
I use solder for electronics and projects that require soldering. There few if any solder requirements in building wiring.
The Following User Says Thank You to J. V. For This Useful Post:
Jim Port (05-04-2013)
Old 05-03-2013, 10:44 PM   #7
I believe that the NEC (110.14b) continues to permit soldering as a valid wire splicing technique provided the splice is first made in a mechanically secure fashion..
kwilcox is offline   Reply With Quote
Soldering copper pipe in tight location- Help Needed Pics included amodoko Plumbing 20 08-11-2012 04:14 PM
How to protect PVC pipe when soldering near it? Studly Plumbing 8 11-21-2011 10:10 AM
Soldering Paste - Good or Bad ? Mike Mike Plumbing 5 03-09-2011 08:59 PM
Soldering question Polyknikes Plumbing 9 08-29-2010 08:58 AM
Soldering? Dont try radioshack 15/30w dual heat soldering iron! rgsgww Off Topic 2 03-14-2009 10:56 PM
