Solar Powered Electricity - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2007, 08:37 PM   #1
Question
solar powered electricity
Which is more affordable, solar panels or wind turbines?
specialk is offline   Reply With Quote
Old 07-14-2007, 09:46 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Where are you and how much wind and sun do you have?
Some areas do not have enough sun, while others may not have enough wind, so there may be no choice on your alternate energy source.
Solar powered equipment and wind powered equipment sellers can tell you about the viabilty based on weather records.
Can you build a tower where you are? Some areas only allow solar collectors on a "non-street" side.
Wind can be a 24 hour possibility and you may be able to sell power back to your utility.
concretemasonry is offline   Reply With Quote
Old 07-15-2007, 09:22 AM   #3
Agent 000
SecretSquirrel's Avatar
'Affordability' is a very subjective thing. Payback should be looked at instead of installation cost.
The payback time for solar electrical generation is longer than wind driven generation.
See; This article
However, if you search for payback periods for either technology you'll find the estimates to be all over the place. But the general consensus is; Solar is more expensive in terms of payback, not to mention some solar system components do have a 'lifetime'; i.e. storage batteries and the solar cells themselves.
SecretSquirrel is offline   Reply With Quote
Old 07-15-2007, 09:53 AM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
You can't forget about maintenence as well. I would imagine that a turbine would require a lot more maintenence than solar panels. That would add time to your ROI.
Do you have a lot of wind in your area. If I were to put turbines up in my backyard, not only would my neighbors think I'm crazy (and they would be right) but it would probably only work a few times a year. In Seattle, they don't have as many sunny days so maybe wind would work better.
So which is more affordable is dependant on you location.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Topic Suggestions Nathan Site Help and Suggestions 48 01-20-2009 09:21 AM
