Solar Pool Heater! - Electrical - DIY Chatroom Home Improvement Forum
Old 05-13-2011, 02:20 PM   #1
Rewards Points: 79
Solar pool heater!
Hope this question is not too far out of scope for this forum.
We have a pool and would like to heat it from the sun. We plan to build a fake black rock waterfall with a pool of water feeding it from the top. If it runs all the time, it will actually cool off the pool when the temps are colder. I’m looking for some sort of thermostat / timer combination that would work like this.
The thermostat sensor would be placed in the pool of water at the top of the fall. When the temp hits, say 85 degrees (adjustable of course), it turns on the electric current that goes through a timer that will keep it running for again, say 30 minutes (adjustable again). This way I only circulate water through my fake black rock feature when the sun is heating up the structure.
Does anyone have any idea what parts I should be looking to put together for something like this?
papageek is offline   Reply With Quote
Old 05-13-2011, 06:39 PM   #2
Lic Elect/Inspector/CPO
Is this going take the place of the existing water return the pool pump
NJMarine is offline   Reply With Quote
Old 05-13-2011, 10:16 PM   #3
Where are you located ?
How big is your pool -gallons ?
I'm not sure how much heating you will get from a fake rock waterfall
I use a 4x12 panel to heat my hot tub to 105+ in the summer
I also use several 2x20' panels to heat my inground pool ~19,000 gallons
I've had the pool up to 96 in the summer
Old 05-16-2011, 09:09 AM   #4
Rewards Points: 79
We are in the north east corner of Maryland. We are doing this as much for the water feature as for the heat. As long as we are adding the water feature, might as make it somewhat functional. Runnign it when the sun is not on it will cool down the pool and we don't want that!
Old 05-16-2011, 09:17 AM   #5
Rewards Points: 1,418
Put the thermostat in the coolest section of the black structure where the sun does not hit the thermostat even if the thermostat is at the bottom of an open tank of water.
Old 05-16-2011, 12:39 PM   #6
wareagle's Avatar
I thought you used the pool to cool off.
wareagle is offline   Reply With Quote
Old 05-17-2011, 02:04 AM   #7
" Euro " electrician
frenchelectrican's Avatar
Papageek.,
I will suggest that you talk to Scuba Dave if you need more details and I know there were a pretty good details on what he did with pool solar and spa panels IMO they did dammed good job to keep the water very warm few case more than anyone will expected how much it perforaced.
So either post the message or PM him either way he will help you with details if you are instering with it.
Merci,
Marc
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Removing a pool heater thehvacguy Plumbing 5 03-17-2011 02:00 AM
How to flush water heater that has solar panels Homerepairguy Plumbing 2 11-11-2010 09:26 PM
Pool timer on an electric water heater...Yes or no? Gusaroo Plumbing 2 09-01-2008 09:13 AM
Pool Care Guide scottiedog Landscaping & Lawn Care 16 06-07-2008 09:41 PM
