Solar Panels And Grid-tied System - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-16-2012, 07:06 PM   #16
Originally Posted by Savedoux View Post
Hello. Your solar system looks impressive.
Do you mind discussing in detail how you grounded your solar panels, equipment, etc in regards to an earth ground? Any thoughts on grounding and how to approach it with a small solar system such as mine. See below
3- 80w 12v pv panels wired in parallel mounted to roof approx 30ft from earth
225 AH battery bank
15a mppt charge controller
1500 watt inverter
AC breaker panel connected to inverter
Thanks!
I used 1 inch self tapping screws and screwed copper lay in Lugs on every panel . I did this on every panel and I used bare awg 6 gauge. From there I sunk a 5/8 ground rod and fastened the 6 gauge to the ground rod with a acorn clamp. I would also recommend grounding your inverter to the rod also. I hope that helps. If you have anymore question feel free to ask.
Electric Guru is offline   Reply With Quote
Old 11-16-2012, 07:09 PM   #17
The SMA Sunny Boy 8000 Watt Inverter
Solar panels 3 gauge wire zman22 Electrical 7 11-09-2011 09:47 PM
Grid Tie Solar Panel Manual Transfer Switch Possible? tomguy Electrical 5 04-08-2011 03:55 PM
Wiring solar panels - what is needed? sheslostcontrol Electrical 8 12-18-2010 05:48 PM
Solar Cell connection to grid Roxelectric Electrical 9 07-27-2009 05:04 PM
Anyone here played around with Solar power/pannels? ehoez Electrical 18 02-10-2009 12:24 PM
