Old 08-17-2010, 02:16 AM   #1
solar panel troubles
Installation previously done by solar city with out permits as well as main 400 amp panel upgrade.Yes not to professional;Now I am involved with city permits as well as re connection of solar system.All is good with main distribution.Upon connection of solar lines i simply replaced the wires on same phases as in old 400 amp service load side of meter.prior i had shut down all disconnects as well as main feeders.Once re placed on load side of meter all seemed well .now i have received call from customer they have not received credit on their bill. yet they are under construction.the old 400 amp meter had drilled lugs between meter and main am i missing something he this seems pretty self evident .Is it possible the meter went bad they are in an area with many brown outs .
william2007 is offline   Reply With Quote
Old 08-18-2010, 01:46 AM   #2
Semi-Pro Electro-Geek
This is pretty much incomprehensible without a diagram, or at least a complete description of the system and its current state of operation. How many inverters? How are the disconnects set up? What meters/indicators exist, and what measurements have been taken?
mpoulton is offline   Reply With Quote
Supplemental Solar Heat Panel rocketmotor HVAC 29 03-22-2010 06:31 AM
How to Increase the Watts in my Solar Panel? rdlrn19 Green Home Improvement 1 03-02-2010 07:55 PM
Multiple Panel Question theatretch85 Electrical 5 12-12-2009 06:26 AM
Solar Panel sneech Electrical 9 10-11-2008 07:27 AM
Solar panel for koi pond pump? Badfish740 Electrical 5 02-29-2008 05:29 AM
