Solar Panel Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 06:51 PM   #1
solar panel installation
I'm installing my own solar panels. I understand that connecting to my box is as simple as simply running AC cable from inverter to main panel and simply plug into an existing open circuit. For 5592 watts AC how big a breaker do I need to connect into?
jfforster is offline   Reply With Quote
Old 10-13-2012, 07:18 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Not nearly that simple and if you think so, you need a licensed professional with solar experience.
Coastal South Carolina
Old 10-13-2012, 09:00 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
jf.....the fact that you can' figure that part out indicates you're way in over your head....that is some of the easiest math there is...
To answer your question....if it's 240vac....25A....120Vac.....50A
I'm assuming your adding up the 'potential' output of all of your solar cells...which would be peak output at full sun....which your only going to get for short periods of time....and then you have the losses through your inverter....and the inverter needs a way to sync up to the existing house AC freq (must be perfectly in phase)....
I'm inclined to agree with rjniles.
Old 11-06-2012, 04:58 PM   #4
An old Tradesmen
Rewards Points: 6,466
Plus the inverter must drop out when it doesn't detect any voltage coming in from the meter. So as to have no potential to electrocute a linesmen.
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Grid Tie Solar Panel Manual Transfer Switch Possible? tomguy Electrical 5 04-08-2011 04:55 PM
Installation of a sub panel rprudil Electrical 10 11-01-2010 12:47 PM
Passing wire to another panel theatretch85 Electrical 5 09-21-2009 12:09 AM
Aluminum solar panel frame ideas wanted easytim Building & Construction 5 08-03-2008 03:40 PM
