Old 04-09-2011, 09:33 PM   #1
solar panel electrical conduit
Does wiring to solar panels have to be in conduit?
reaganw is offline   Reply With Quote
Old 04-09-2011, 10:06 PM   #2
nap
You talking to me?
nap's Avatar
that would depend on a lot of things. "to solar panels" is a bit vague. What kind of voltage and current are you talking about in this wire?
Old 04-10-2011, 01:16 AM   #3
" Euro " electrician
frenchelectrican's Avatar
It depending on the size of solar panels however AFAIK most solar panels I have dealt with it they are ran in conduit and have a disconnection switch as well.
The best answer is you check with your local inspector for the latest informaton related to the solar panels.
And if you going to tie with the POCO grids you will need a net metering device or other means and have POCO involded with this.
The last one I just have one sometime back it is a 100 KW solar panels it cover pretty good section of roof decking and one nice big plus that it actually reduce the amout of A/C need to keep the place cool as well.
Merci,
Marc
Old 04-12-2011, 04:16 PM   #4
the systems i have seen and wired have exposed wires from the panels until they enter the building. then into j box and conduit to inverters (inside).
migas is offline   Reply With Quote
solar panel troubles william2007 Electrical 1 08-18-2010 01:46 AM
Fireblocking around electrical service panel dbmjmj Building & Construction 0 07-11-2010 06:51 PM
Question about outdoor panel, conduit and derating wire pttcc Electrical 10 02-15-2010 11:51 AM
Need to change my electrical panel? 2nd opinion needed I_have_questions Electrical 60 01-30-2009 10:38 AM
Solar panel for koi pond pump? Badfish740 Electrical 5 02-29-2008 05:29 AM
