#1 |
Solar Light - Suggestions Requested
I am looking a solar light or two that I can use in my shed, as I have no power going to it. The idea would be to have the solar panel on the outside wall of the shed, and run the wire to a light inside the shed. Making it one better would be if it could just store the juice until I turn the light on.
Looking for opinions, good or bad, on brands and types of lights I can find and use. |
#2 |
the Musigician
i had this exact problem.... i needed to see the water level in the cistern way back in a dark corner of our tornado shelter. i already had 2 solar "cycle battery" chargers, so i wired a line from them, (upstairs in a window in the shed built on top of the shelter) to an LED flashlight that just hung above the cistern down below. if the sun was out, the flashlight was lit brightly. i could have easily placed a battery in the lineup too, but saw no need. the flashlight was only a few dollars and has lasted years, and i only see one LED bulb that has fried!
(thanks for this thread, it got me to go check my system!) DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
#3 |
The key is total "wattage" of the lights you will be using AND how long at night you will want to have these lights on.
Solar panels are rated by "watts". This is the ability of the solar panel to "recharge" a battery. A very small wattage solar panel might take a week to recharge a small battery, but a higher wattage solar panel might be able to recharge a battery in a few hours. Then there is a gizmo called a "charge controller". This regulates the charging of batteries. And then there is a gizmo called an "inverter". This converts battery power into regular house electricity. As to batteries, a small fully charged battery will power a small light all night, but might only power a higher wattage light for a few hours. Whereas a large battery might power several lights all night. Or several large batteries connected together would power more things. Or power things longer. Here is all sorts of information on this... http://www.energysavers.gov/your_hom.../mytopic=10710 http://www.solar-electric.com/ http://www.windsun.com/General/links.htm Examples of Kits... http://www.amazon.com/HQRP-Monocryst.../dp/B002WHQPDA http://cgi.ebay.com/ws/eBayISAPI.dll...=263602_263622 http://www.newegg.com/Product/Produc...nc.-_-82260027 |
#4 |
I bought one a few years ago online from Northern Tools I think it was. Was direct for your application. Consisted of a solar panel, a light with battery, and interconnection wire. Was not a whole lot of money if I recall, maybe $75 or so.
#5 |
The all in one deal from Northern Tools sounds about what i am looking for, just an all in one deal I can buy and install.
#6 |
Xtreme DIY'r
Lights will also last much longer if they are LED
I have (5) LED MR16 lights that point along my main room ceiling They draw just under 2w each, with the power pack about 10w total Each one has 32 LEDs, pointed down they light up a large area I have 3 more over my peninsula in the kitchen One power pack I have is good for 40w = about 20 of the LED lights
#7 | |
Solar Light - Suggestions RequestedQuote:
http://www.northerntool.com/webapp/w...5188_200365188 http://www.northerntool.com/webapp/w...6364_200396364 http://www.northerntool.com/webapp/w...1123_200371123 |
| Display Modes | |
| Please Help! 3 way switches controling 2 light fxtures. | HelloMotto | Electrical | 50 | 09-01-2009 09:20 PM |
| Can I use recessed light wiring for a regualr light? | integrity634 | Electrical | 1 | 03-18-2009 07:29 PM |
| Wiring from light to switch and on | poorjohn | Electrical | 3 | 03-16-2009 02:23 PM |
| Hall light worked before installing a new light fixture in bathroom | jcfan7 | Electrical | 40 | 02-23-2008 10:46 AM |
| Hot Light Outlets | Materials Guru | Electrical | 5 | 07-31-2006 08:11 PM |
