Old 04-20-2008, 12:28 PM   #1
Default Solar Charged Brushless Lawn Mower
While not quite a renovation (unless one renovates the lawn every week when one uses the lawn mower ) I was curious if anyone has any experience with a solar charged brushless electric lawn mower?
I don't understand solar stuff or electrical stuff but lots of y'all seem to by the posts in this ara of the forum.
We recently purchased the new solar charged lawn mower which is being sold at a few retail outlets in the Boston & Seattle areas as well as throughout Canada that uses a solar charging station so the mower is completely off grid.
We chose the 19 inch model (also comes in a 21 inch model), is self propelled, etc., etc., (i.e. does all the stuff a mower can or should). The solar charging station was easier to install than I thought and once the batteries become fully charged in the next day or two we'll have our first test run. We have started to write some articles in our blog with some pictures,etc. which you can view here using this link to the first article.
But, have I gotten myself into a mess? Is this brushless motor technology for real and if so, which is better, brushless or a brush type of motor for an electric lawn mower?
As well, what about the solar charging station? How long do those panels actually last? If I lay it horizontal (which I have done) could it be damaged by a hail storm or a strong rain storm?
Thanks for your experinces,
Dan
Educator is offline   Reply With Quote
Old 04-20-2008, 02:32 PM   #2
Idiot Emeritus
It'll be interesting to see how this pans out, but I'd bet it works ok.
Brushless DC motors come in two types that I know of. The first is a true DC motor that uses electronic commutation. In a brush-type DC motor, current is transferred (commutated) to the rotor (the part that turns) through brushes that ride on segmented bars (the commutator). In the brushless type, this is done electronically.
The second type uses a DC source to power an AC motor through an inverter. One example of this is the variable frequency drive. The speed of most AC induction (brushless) motors depends on frequency, not voltage. (There are exceptions, like variable speed ceiling fans, etc.). If the frequency of an AC motor is varied, with an appropriate voltage change, its speed will change accordingly, but it can maintain its full rated HP or torque. VFDs can be applied to motors of less than 1HP or more than 1000HP.
A VFD works like this; first the incoming AC power is converted to DC, then is re-inverted back to AC at whatever frequency is selected. This is necessary because the frequency of the incoming AC power cannot be changed.
If the VFD is fed with a DC source on the DC bus, it'll work just fine. The inverter part doesn't care what the source of the DC is. It only cares that it is DC power of appropriate voltage and current.
I suspect this mower uses this type of technology.
When VFDs first came out, they were notoriously unreliable. In my experience, about 8 out of 10 failed in the first 6 months. They're much better now, I doubt that 1 out of 100 will fail these days.
I think the biggest problem you'll have is batteries. They're temperature sensitive, don't like to be left uncharged for any length of time, and don't like to be overcharged. Hopefully, there's some sort of charge controller between the solar cells and the batteries.
Rob
micromind is offline   Reply With Quote
Old 04-20-2008, 02:43 PM   #3
Rob
Hi Rob,
Thanks very much for this. I certainly appreciate the time you took.
Yes, the solar charging station has a 'controller' which is supposed to prevent the batteries from over charging. And, yes, the manufacturer's instructions state to leave the batteries in the charger when not being used in the mower. As well, per the manufacturer's information, we won't be leaving the batteries out in the winter as they are not supposed to freeze otherwise some type of damage can occur.
Dan
More On This Topic
Hi I'm Larin Parker with Expert Village and I'm going to show you how to check voltages. This is another great way to diagnose things when you have no idea, what's going on. You turn it on and you get no result. We are looking at the back of this radio... Read More »
Robbie speaking for expert village. We're going to talk now about the electric or battery operated motors for the other side of the hobby. We were talking about the nitro engines before. Electric motors are the more simple ones you will find them in the... Read More »
When you need to pump water to a distant field, sometimes it's not convenient to run the pump with electricity. In such an application, a solar pump works well. Fortunately, you can do this yourself. This eHow can help you get started. Read More »
When the batteries are full or even if they are not quite full, with these big wires here, the energy runs to this inverter. The inverter is an electronic and electric unit that is able to use the 24 volts that are going in here and then changing it from... Read More »
Hello. This is Jeff Naylor from Mtroniks Engineering in Mesa, Arizona for Expert Village. Now we're going to show you how to bias your tubes in this amplifier. But first let me tell you what bias is. Bias is a DC voltage applied to the same point of the... Read More »
fix my Lawn Mower Starter myself !!! KUIPORNG Landscaping & Lawn Care 10 06-28-2009 03:34 PM
Installing Solar Panels on Your Home or Business doctorhouse Building & Construction 6 09-04-2008 11:23 PM
briggs stratton 4hp lawn mower high idle truebaca Landscaping & Lawn Care 0 07-31-2007 10:27 PM
Riding Lawn Mower Washer Willy Landscaping & Lawn Care 2 03-23-2007 02:25 PM
Rotary Lawn Mower jarg Landscaping & Lawn Care 9 07-03-2005 04:37 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
