Solar- Can I Tie Into The Electricity Generated On A Distant Outbuilding - Electrical - DIY Chatroom Home Improvement Forum
Old 08-15-2012, 02:46 PM   #1
Solar- can I tie into the electricity generated on a distant outbuilding
Just installed new on grid solar panels with inverter on a distant outbuilding. The outbuilding has no electricity. IS IT POSSIBLE TO TIE INTO THE SOLAR AFTER THE SOLAR GENERATION METER.
Outbuilding Electric configuration is currently solar panels to inverter to solar meter then out to my main service at the house where there is a disconnect and NET metering.
JStofik is offline   Reply With Quote
Old 08-17-2012, 07:16 PM   #2
Rewards Points: 266
If I understand you correctly, the answer is yes. You must have an AC 120/240 connection to the main panel from your outbuilding since the inverter is there. Ask your solar installer to come back and add some outlets or lights, whatever.
ionized is offline   Reply With Quote
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Questions about providing electricity to an outbuilding drichards Electrical 4 12-11-2010 11:07 AM
How to flush water heater that has solar panels Homerepairguy Plumbing 2 11-11-2010 08:26 PM
solar powered electricity specialk Electrical 3 07-15-2007 08:53 AM
